[gdal-dev] Creating derived raster bands using python
Thu Mar 5 09:26:51 EST 2009
Antonio Valentino wrote:
> Hi list,
> I'm trying to create a *Derived* raster band in a virtual dataset.
> All my attempts seems to fail:
>>>> ds.AddBand(options={'subClass': 'VRTDerivedRasterBand'})
> raises an exception while
>>>> ds.AddBand(options='subClass="VRTDerivedRasterBand"')
>>>> ds.AddBand(options=['subClass="VRTDerivedRasterBand"'])
Antonio,
I believe the correct syntax is:
   ds.AddBand(options=['subClass=VRTDerivedRasterBand'])
The options should be a list of name=value pairs.  Your extra double
quotes within the string will make the class name comparison fail
since you are effectively passing "\"VRTDerivedRasterBand\"" in C
terms.
Best regards,
