[gdal-dev] Bigtiff question
Even Rouault even.rouault at mines-paris.org
Thu Mar 5 15:09:54 EST 2009
Le Thursday 05 March 2009 20:45:49 Lucena, Ivan, vous avez écrit :
> Even,
> >  for the very poor performance when dealing with pixel interleaved GTiffs
> > with a large number of bands, I think you've hit ticket #2838 that has
> > been fixed 3 weeks ago in trunk and branches/1.6 (*). The performance
> > issue was about *reading* in such files, but sometimes when you write and
> > the block cache size is not big enough, you also end up reading back
> > partially written scanlines. Hopefully this would correct the problem you
> > observe.
> Ah!
> >  But as Frank suggested, I would not recommand using pixel interleaved
> > GTiffs with a large number of bands anyway. This is fine for RGB or RGBA
> > datasets, but for more bands, it could cause cache trashing problems as
> > we prefill the blocks for all bands in pixel-interleaved mode (#2838 was
> > about the fact this technic wasn't correctly implemented)
> What raster format would you suggest then?
> I mean, based on those requirements:
> - Multiband;
> - Large files;
> - Good performance *reading* the data in pixel space. Not the "band as
> usual" ;)
Have you tried a tiled (128x128) band-interleaved GeoTIFF instead ? And read
block per block. In any event, you should be careful than the block cache
size is at least blockXSize * blockYSize * sizeof(datatype) * nbands.
> >  #!/usr/bin/python
> >  import gdal
> >  driver_tif = gdal.GetDriverByName("GTIFF")
> >  output_dst = driver_tif.Create( 'test.tif', 20, 20, 320, gdal.GDT_Byte,
> >  [ 'TILED=NO', 'INTERLEAVE=PIXEL' ])
> >  for i in range(320):
> >      output_band = output_dst.GetRasterBand( i + 1 )
> >      output_band.Fill(i + 1)
> >      output_band.FlushCache()
> >  output_dst = None
> My real data is 5000x2500x312 Int16, can you try with:
>   output_dst = driver_tif.Create( 'test.tif', 5000, 2500, 312,
> gdal.GDT_Int16, [ 'TILED=NO', 'INTERLEAVE=PIXEL' ])
This is too large for my modest PC. I've tried up to 10 bands 5000x2500 and it
worked fine.
> My best regards,
> Ivan
