[gdal-dev] saving numpy array as ascii raster
Oz Nahum oz.nahum at student.uni-tuebingen.de
Thu Mar 5 15:45:24 EST 2009
Thanks for your quick reply.
When I edit my code function to be:
def WriteRaster (dst_filename, raster):
        format = "AAIGrid"
        driver = gdal.GetDriverByName( format )
        dst_ds = driver.Create( dst_filename, 71, 73,\
              1,gdal.GDT_Float32,options=["COMPRESS=PACKBITS","TFW=YES"] )
Python complains:
ERROR 6: GDALDriver::Create() ... no create method implemented for this
format.
alsp
>This file must be the .tfw, right?  I expect you created a geotiff file as
>well which is where your data is.
True, a file with the suffix I choose. This file is binary and I can't see
it.
So I would rather use the code supplied to save as text. This however is
still not successful,
Thanks,
Oz.
On Thu, Mar 5, 2009 at 9:28 PM, Bryan Keith <bryan at ideotrope.org> wrote:
> > Hello Again,
> >         format = "GTiff"
> Oz,
> You're creating a geotiff.  Try:
> format = "AAIGrid"
> These options won't be available for "AAIGrid".
> >         dst_ds.SetGeoTransform( [-19.5, 1.0, 0.0, 37.5, 0.0, -1.0] )
> >         srs = osr.SpatialReference()
> >         srs.ImportFromEPSG(4326) #WGS84 lat long.
> >         dst_ds.SetProjection( srs.ExportToWkt() )
> >         dst_ds.GetRasterBand(1).WriteArray( raster )
> >         dst_ds = None
> > c= a+b
> > print c
> > WriteRaster ('raster3.gtiff', c)
> > A file with following content is created:
> > 1.0000000000
> > 0.0000000000
> > 0.0000000000
> > -1.0000000000
> > -19.0000000000
> > 37.0000000000
> Bryan
           Imagine there's no countries
           It isn't hard to do
           Nothing to kill or die for
           And no religion too
           Imagine all the people
           Living life in peace
          You all must read 'The God Delusion'
          http://en.wikipedia.org/wiki/The_God_Delusion
when one person suffers from a delusion it is called insanity. When many
people suffer from a delusion it is called religion."
Robert Pirsig, Zen and the Art of Motorcycle Maintenance
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090305/a7656fb2/attachment.html
