[gdal-dev] setargv with windows 64-bit
Tamas Szekeres szekerest at gmail.com
Fri Mar 6 10:28:42 EST 2009
Jeff,
I'm guessing you're linking against an incorrect version of setargv.obj. I
see the Win64 version can be found in:
C:\Program Files (x86)\Microsoft Visual Studio 8\VC\lib\amd64
if you use VC2008 for example.
Best regards,
Tamas
2009/3/6 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> I am building a 64-bit GDAL on a 32-bit windows machine, and enabling
> setargv throws this GDAL error when compiling:
>        cd apps
>        nmake /nologo /f makefile.vc
>        cl /nologo /MD /EHsc /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_N
> O_DEPRECATE /DNDEBUG -I..\port -I..\ogr -I..\gcore  -I..\alg
> -I..\ogr\ogrsf_frmt
> s    -I..\frmts -I..\alg -I..\ogr -I..\ogr\ogrsf_frmts gdal_translate.cpp
> "D:\So
> ftware\MICROS~1.0\VC\lib\setargv.obj" ..\gdal_i.lib  /link
> gdal_translate.cpp
> D:\Software\MICROS~1.0\VC\lib\setargv.obj : fatal error LNK1112: module
> machine
> type 'X86' conflicts with target machine type 'x64'
> NMAKE : fatal error U1077: '"D:\Software\Microsoft Visual Studio
> 9.0\VC\BIN\x86_
> amd64\cl.EXE"' : return code '0x2'
> Stop.
> 9.0\VC\BIN\nmak
> e.EXE"' : return code '0x2'
> Stop.
> If I don't enable setargv GDAL 64-bit compiles fine (using today's GDAL
> trunk).  (I have set GDAL's "WIN64" flag)
> Any ideas why this error is happening?
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090306/ab672c61/attachment-0001.html
