[gdal-dev] Building 64 bit, Swig Error
Tamas Szekeres szekerest at gmail.com
Fri Mar 6 17:08:30 EST 2009
There's something missing in your vcvars.bat  (ie vcvarsx86_amd64.bat for
the cross compiler version). Try to check the FrameworkDir and the PATH
environment variables to match with the current locations within the batch
file, like for example:
@SET FrameworkDir=C:\WINDOWS\Microsoft.NET\Framework64
@set
PATH=%VCINSTALLDIR%\BIN\amd64;%FrameworkDir%\%Framework35Version%;%FrameworkDir%\%Framework35Version%\Microsoft
.NET Framework 3.5 (Pre-Release
Version);%FrameworkDir%\%FrameworkVersion%;%VCINSTALLDIR%\VCPackages;%VSINSTALLDIR%\Common7\IDE;%VSINSTALLDIR%\Common7\Tools;%VSINSTALLDIR%\Common7\Tools\bin;%PATH%
@set INCLUDE=%VCINSTALLDIR%\ATLMFC\INCLUDE;%VCINSTALLDIR%\INCLUDE;%INCLUDE%
@set LIB=%VCINSTALLDIR%\ATLMFC\LIB\amd64;%VCINSTALLDIR%\LIB\amd64;%LIB%
@set
LIBPATH=%FrameworkDir%\%Framework35Version%;%FrameworkDir%\%FrameworkVersion%;%FrameworkDir%\%Framework35Version%;%FrameworkDir%\%FrameworkVersion%;%VCINSTALLDIR%\ATLMFC\LIB\amd64;%VCINSTALLDIR%\LIB\amd64;%LIBPATH%
Best regards,
Tamas
PS: You could also download the recent SDKs or precompiled binary packages
for various compiler versions from this location:
http://vbkto.dyndns.org:1280/sdk/index.html
2009/3/6 Tomas R <monshi at home.se>
> Trying to build a 64 bit version of GDAL on  a Vista 32 bit installation
> using Visual Studie Express C++ 2008.
> So how do I do, and how does it go.
> I start up the Visual Studio 2008 x64 Cross Tools Command Prompt. I set in
> nmake.opt WIN64= YES
> With this GDAL seems to compile ok, no errors and all files created as it
> should. I have no direct way of testing it since I only have a 32 bit
> installation of Vista but, as said, seems ok.
> Then I try to compile the C# Swig interface.
> First step
> nmake /f makefile.vc interface
> compiles
> but second step
> throws an error
> cd ..
> csc  /target:library /out:osr_csharp.dll osr\*.cs AssemblyInfo.cs
> csc är inte ett internt kommando, externt kommando,
> program eller kommandofil.
> NMAKE : fatal error U1077: 'csc' : return code '0x1'
> Stop.
> translates to about
> csc is not an internal commando, external commando, program or commando
> file
> What have I missed?
> Building 32-bit version, using the normal  32 bit version of VSE 2008 debug
> environment is no problem at all.
> Yours
> Tomas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090306/c0d4318c/attachment-0001.html
