[gdal-dev] Re: Building 64 bit, Swig Error
Tomas R monshi at home.se
Sat Mar 7 11:47:20 EST 2009
Yes, you are correct. But is not only me who make use of the
GDAL-plugin. It not easy to get all plugin updated and get all users to
updated both gdal and the plugins using gdal.
/Tomas
Tamas Szekeres skrev:
> I think you'd just have to replace the reference to this version of
> gdal_csharp.dll and recompile the project.
> Best regards,
> Tamas
> 2009/3/7 Tomas R <monshi at home.se <mailto:monshi at home.se>>
>     Thanks, it works. Just set the path.
>     Proj4 I think I will grab from your compilation. Should work good
>     enough. I will compile GDAL myself to keep it minimal. Only need
>     the Proj4 library as far as I know.
>     Sadly, it seems a straight upgrade from, 1.5 is not possible. That
>     is, my use of GDAL is to create a plugin to SportTracks making
>     GDAL available to other plugins. Plugins linked via csharp
>     libraries to 1.5 version seems not to find the 1.6 version, they
>     will need to be updated to work.
>     That's just how it is I guess.
>     Thanks
>     /Tomas
>         If you use my SDK just download and extract the proj4 package
>         (eg.  proj-4.6.1) within the SDK root directory and use:
>         nmake proj PROJ_DIR=proj-4.6.1
>         The Makefile will set the compiler version and the WIN64
>         setting seemlessly.
>         It seems like the @SET FrameworkDir=Framework32  should point
>         to the absolute path of the framework directory (ie
>         C:\WINDOWS\Microsoft.NET\Framework) in your batch file.
>         Best regards,
>         Tamas
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
