[gdal-dev] ogr2ogr: shp > kml, coordinate precision and related kml file size
Christopher Condit condit at sdsc.edu
Mon Mar 9 13:25:42 EDT 2009
Hi Hermann,
> In my context, Lat/Lon values with 6 decimals are just about enough
> precision. I feel that I am pumping a lot of meaningless numbers into
> the kml file, which makes it big. Is there an option to reduce the
> number of decimals for transformed coordinates?
See http://trac.osgeo.org/gdal/ticket/2461 for information about this...
> However, and based on my limited understanding: I do not need 3
numbers
> to describe a point in a 2D system, do I? How can I strip the height
> coordinate (and why is it there in the first place?).
I think you can use the nlt option to at least make the input 2.5 D and
then strip the Z value off, effectively removing the height. It may be
related to the CS transformation but I'm not sure without seeing your
actual input file.
-Chris
