[Gdal-dev] No support for widestrings in ArcSDE driver for OGR ?
Anders Moe anders.moe at geocap.no
Tue Mar 10 09:49:28 EDT 2009
Hi
I'd be happy to test this out for for ArcSDE 9.2 (9.3 a bit later). I've
just pulled the latest stable and saw no change to the ArcSDE driver related
to widestrings I applied my own private patch as a workaround (attached).
Regards,
Anders.
> I would fix it myself and submit a patch, but ironically enough, I don't
> have a way to test it or compile it since I don't have ArcSDE nor ArcGIS
> anywhere... should I submit a ticket?
Ragi,
I'm in the same position - no SDE instance to test against.  A patch might
be good if either Howard or Anders are willing to commit to testing it out.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://n2.nabble.com/file/n2455262/d.txt d.txt
View this message in context: http://n2.nabble.com/No-support-for-widestrings-in-ArcSDE-driver-for-OGR---tp2036034p2455262.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
