[gdal-dev] GDAL / PROJ.4 Transformation (cs2cs) - several results by  PROJ.4-Versions (DHDN/GK2 => ETRS89/UTM32)
Gregor Fikoczek gregor.fikoczek at wheregroup.com
Thu Mar 12 04:29:21 EDT 2009
Hi list,
i am using the PROJ.4 (cs2cs, GDAL/OGR, UMN MapServer) for transformation
from CS to CS.
start-point (DHDN / GK 2 => epsg:31466)
5216100002;2552401,862;5616707,524
correct destination-point (ETRS89 / UTM 32 => epsg:25832)
32340408.033  5617072.487
example:
cs2cs +init=epsg:31466 +to +init=epsg:25832
 2552401.862 5616707.524
Result with PROJ.4 version 4.5.0:
340411,268580576754175;5617068,431440304964781
=> difference to the correct destination point in ETRS89: ~ 5 m
=> fine
Result with PROJ.4 version 4.6 and 4.6.1:
340463.83       5617207.67
=> not so fine / wrong
=> difference to the correct destination point in ETRS89: > 100m
====> Why the difference in PROJ.4 Version 4.6 and 4.6.1 is the much?
epsg-FILE:
# ETRS89 / UTM zone 32N
<25832> +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs  <>
# DHDN / Gauss-Kruger zone 2
<31466> +proj=tmerc +lat_0=0 +lon_0=6 +k=1 +x_0=2500000 +y_0=0
+ellps=bessel +datum=potsdam +units=m +no_defs  <>
When i modified the epsg file like this (add parameter +datum=WGS84 to
EPSG:25832):
from
to
<25832> +proj=utm +zone=32 +ellps=GRS80 +datum=WGS84 +units=m +no_defs  <>
... the result is as expected and equal like by the PROJ.4 Version 4.5.0.
Result:
 340411.27      5617068.43
==> fine
So is there a difference between PROJ.4-Versions (Version > 4.5 needs
+datum-Parameter?) or am i doing something wrong?
Best Regards,
Greg
Mit freundlichen Grüßen / Kind regards
Gregor Fikoczek
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek at wheregroup.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
