[gdal-dev] GDAL / PROJ.4 Transformation (cs2cs) - several results by PROJ.4-Versions (DHDN/GK2 => ETRS89/UTM32)
Gregor Fikoczek gregor.fikoczek at wheregroup.com
Thu Mar 12 07:40:31 EDT 2009
hi Jean-Claude,
thanks for the information,
Best regards,
Greq
Am Donnerstag 12 März 2009 11:55:50 schrieb Jean-Claude Repetto:
> Gregor Fikoczek wrote :
> > So is there a difference between PROJ.4-Versions (Version > 4.5 needs
> > +datum-Parameter?) or am i doing something wrong?
> Hello,
> In the prog 4.6.0 release notes, one can read :
>   o MAJOR: Rework pj_transform() to avoid applying ellipsoid to ellipsoid
>     transformations as a datum shift when no datum info is available.
> So yes, a datum definition is mandatory if you want to perform a
> transformation.
> The definition of epsg::25832 in the epsg file is incorrect.
> Regards,
> Jean-Claude
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek at wheregroup.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
