[gdal-dev] GRIB driver crashes with large numbers of bands
Fri Mar 13 11:35:00 EDT 2009
Jose Gómez-Dans wrote:
> Hi,
> I have some GRIB datasets downloaded from ECMWF
> <http://data-portal.ecmwf.int/data/d/interim_daily/>. The files contain many
> bands (19728). When I try gdalinfo on these datasets, it waits for a long
> time. The python bindings segfault. The driver does fine with a smaller
> dataset (around a third of the layers, some 6500).
> Is this a bug or is this a limitation of the grib driver?
I would appreciate it if you could file a ticket on this with a pointer
to a specific dataset to test with.  I'm not surprised that things perform
poorly with such a dataset, but we would like it to at least error out
cleanly rather than crash.
Best regards,
