[gdal-dev] Access to MetaData in driver implementation
Fri Mar 13 11:58:11 EDT 2009
lidiriel wrote:
> Hello,
> I work on th create method for ISIS2 file (PDS driver). I can write
> raster file but i have a problem with meta data.
> In the case where the user would be use "poDriver->CreateCopy" i try
> to copy and write metaData in the new file. But now i get metadata
> with the method "char** metaData = GetMetadata();"
> But the list of string is not easy to handling.
> Is there another solution for access to the metadata for creating a new
> (or updated copy) of header ?
> Construct and access to an XML tree (like TrySaveXML) ? or another
> method ?
Lidiriel,
You can also request individual items from the source dataset
using GetMetadataItem().  The functions CSLFetchNameValue(), and
CPLParseNameValue() from gdal/port/cpl_string.h should also make
it fairly easily to search for particular keys in a string list and
to decompose an entry into it's name and value portions.
Best regards,
