[gdal-dev] Re: Lossless JPEG in GDAL
Ivan Lucena ivan.lucena at pmldnet.com
Mon Mar 16 01:37:56 EDT 2009
Scott, Jukka, Frank,
The attached file "structure.doc" belongs to the IJG libjpeg source code
distribution and says:
"The library does not support the lossless (spatial) JPEG process.
Lossless  JPEG shares little or no code with lossy JPEG, and would
normally be used  without the extensive pre- and post-processing
provided by this library.  We feel that lossless JPEG is better handled
by a separate library."
Best regards,
Ivan
Jukka Rahkonen wrote:
> Scott Arko <sarko <at> asf.alaska.edu> writes:
>> Frank,
>> Thanks for the idea on filing a ticket.  I will do that.  I tried
>> another suggestion to install Jasper and see if I could load my images
>> as lossless JPEG2000 images, however, this does not seem to work.  For
>> the time being I think I will just write a quick converter using
>> libjpeg, but it would be nice to have support for this in GDAL.  I
>> don't imagine many people run into this file format, though.
>> Best Regards,
>> Scott
> Hi,
> Lossless JPEG2000 images work for me with JP2KAK and JP2MrSID drivers.  JP2ECW
> works partially, only problem being that it makes a lossy output from lossless
> image.  I have never played woth lossless JPEG.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
