[gdal-dev] error with jpeglib while compiling 1.5.4 with MinGW
G. Allegri giohappy at gmail.com
Thu Mar 19 05:12:19 EDT 2009
Hi.
I'm trying to compile gdal 1.5.4 with msys+mingw 5.4.1. I have problems
linking the jpeglib, as internal.
My configure command is:
./configure --prefix=/usr/local --without-grass
--with-sqlite3=/usr/local/sqlite --with-pg=/usr/local/bin/pg_config.exe
--with-local=/usr/local
(I have set --with-local to solve the problem for tiffio, while compilig it
couldn't be found...)
I receive the following error:
*** Warning: This system can not link to static lib archive /usr/local/lib/
libjpeg.la.
*** I have the capability to make that library automatically link in when
*** you link to this library.  But I can only do this if you have a
*** shared version of the library, which you do not appear to have.
libjpeg.la.
libtool: link: rm -fr  .libs/libgdal.dll.a .libs/libgdal.la.lnkscript
libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
libtool: link: g++ -shared -nostdlib
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../dllcrt2.o
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtbegin.o
.libs/libgdal.la.lnkscript  -L/usr/local/sqlite/lib
/usr/local/sqlite/lib/libsqlite3.dll.a -L/usr/local/lib
/usr/local/lib/libexpat.dll.a /usr/local/lib/libtiff.dll.a -L/usr/local/bin
-LC:/msys/local/lib -lpq -lz -LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../../mingw32/lib
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../.. -lstdc++ -lmingw32
-lgcc -lmoldname -lmingwex -lmsvcrt -luser32 -lkernel32 -ladvapi32 -lshell32
-lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtend.o           -o
.libs/libgdal-1.dll -Wl,--enable-auto-image-base -Xlinker --out-implib
-Xlinker .libs/libgdal.dll.a
./frmts/o/.libs/jpgdataset.o: In function `ZN10JPGDatasetD2Ev':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:936: undefined
reference to `jpeg_abort_decompress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:937: undefined
reference to `jpeg_destroy_decompress'
./frmts/o/.libs/jpgdataset.o: In function `ZN10JPGDatasetD1Ev':
./frmts/o/.libs/jpgdataset.o: In function `ZN10JPGDatasetD0Ev':
`ZN10JPGDataset17LoadDefaultTablesEi':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1134: undefined
reference to `jpeg_alloc_quant_table'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1149: undefined
reference to `jpeg_alloc_huff_table'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1168: undefined
./frmts/o/.libs/jpgdataset.o: In function `ZN10JPGDataset7RestartEv':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1196: undefined
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1197: undefined
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1198: undefined
reference to `jpeg_CreateDecompress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1211: undefined
reference to `jpeg_read_header'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1215: undefined
reference to `jpeg_start_decompress'
./frmts/o/.libs/jpgdataset.o: In function `ZN10JPGDataset12LoadScanlineEi':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:964: undefined
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1005: undefined
reference to `jpeg_read_scanlines'
`ZN10JPGDataset4OpenEP12GDALOpenInfo':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1448: undefined
reference to `jpeg_std_error'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1452: undefined
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1485: undefined
`Z14JPEGCreateCopyPKcP11GDALDatasetiPPcPFidS0_PvES5_':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1953: undefined
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1954: undefined
reference to `jpeg_CreateCompress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1971: undefined
reference to `jpeg_set_defaults'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1986: undefined
reference to `jpeg_set_quality'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1991: undefined
reference to `jpeg_start_compress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:2022: undefined
reference to `jpeg_write_scanlines'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:2041: undefined
reference to `jpeg_destroy_compress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:2040: undefined
reference to `jpeg_finish_compress'
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/jpgdataset.cpp:1989: undefined
reference to `jpeg_simple_progression'
./frmts/o/.libs/nitfdataset.o: In function
`ZN11NITFDataset14NITFCreateCopyEPKcP11GDALDatasetiPPcPFidS1_PvES6_':
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3202: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3203: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3221: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3237: undefined
reference to Creating library file: .libs/libgdal.dll.a
`jpeg_set_quality'
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3240: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3242: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3291: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3292: undefined
C:/msys/local/src/gdal-1.5.4/frmts/nitf/nitfdataset.cpp:3273: undefined
./frmts/o/.libs/vsidataio.o: In function
`Z14jpeg_vsiio_srcP22jpeg_decompress_structP6_iobuf':
C:/msys/local/src/gdal-1.5.4/frmts/jpeg/vsidataio.cpp:224: undefined
reference to `jpeg_resync_to_restart'
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-1.5.4'
make: *** [check-lib] Error 2
What's wrong?
giovanni
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090319/03edc031/attachment.html
