[gdal-dev] Splitting and projecting a large .sid image
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 19 19:16:24 EDT 2009
Brent Fraser wrote:
> Steve,
>  My general strategy when doing this (on terabytes of raster data) is:
> 1. Create a tileindex of input data.
> Since you've got multiple zones of raster data, you'll need to create
> one tileindex for each zone (using gdaltindex), de-project them to
> geographic, and concatenate them (use ogr2ogr or PostGIS).
Turns out I already had a set of de-projected bboxes for each image
file. I was going to do this when I found the shapefiles.
> 2. Create a geographic tileindex of output files (via your own script)
> The size, extents, and amount of overlap are up to you.  It doesn't have
> to be a tileindex; it could be just a list of extents for use in steps 3
> and 5 below.
> 3. Do a spatial select for each output tile on the input tileindex to
> create a "mini" tileindex for each output tile.
> I use a hacked version of shputils to do this, but I expect PostGIS or
> ogr2ogr + SQL would be a better way to go.
I loaded the geographic shapefiles into postgis along with my country
boundary polygon and used that to select the tiles the intersected it.
> 4. Convert all the mini tileindexes to vrt files (see the new
> gdalbuildvrt app!)
Oh, I have not seen this. but this is a good idea. I have not use vrt
files much, I need to get them into my thought process.
> 5  Use gdal_translate with the extents from step 2 to extract the output
> tile pixels from its corresponding vrt.
Hmmmm, where do you reproject the raster images? I thought you had to
use gdalwarp for that. Or is that step 6?
> Convoluted yes, but very "scalable".  And no Null pixels in the output
> tiles.
This would be good considering that the tif files are about 1.5-1.7GB each.
-Steve
> Brent Fraser
> GeoAnalytic Inc.
> Stephen Woodbridge wrote:
>> Hi all,
>> This is my annual wake-up got to do something with rasters and forgot
>> the finer details of the last time I did a problem similar to it.
>> I have a bunch of LandSat mrsid imagery, they are in multiple UTM zone
>> projections and I want to convert them to geographic projection,
>> WGS84, and into tiff files. The files are too large to convert into a
>> single tif, so I plan to quarter each file into 4 pieces.
>> So I wrote a script the reads the files and collects info about them,
>> then generates 4 gdalwarp commands to reproject each quarter of the
>> file (perl included below). A typical command looks like:
>> gdalwarp -srcnodata 0 -dstnodata 0 -s_srs +init=epsg:32642 -t_srs
>> EPSG:4326 -te 68.9999676729652 24.9707453133203 72.7715338115736
>> 27.4799559407707 -rb -wm 250 --config GDAL_ONE_BIG_READ ON -co
>> "TILED=YES" ./GeoCover2000/n-42-25.sid ./af/n-42-25_1-0.tif
>> The reprojection seems to have worked fine, but the bounds seem to be
>> off because of the black (nodata) areas.
>> You can see my poor results here:
>> http://imaptools.com/downloads/raster.gif
>> Is there a better way to do this? I seem to remember a tool to
>> generate tiles.
>> Does this need to be done in two steps? How?
>> Did I mess up my logic below? I've been over it multiple times and do
>> not see any errors.
>> Any help would be appreciated.
>> Thanks,
>>   -Steve
>> $ gdalinfo -nomd ./GeoCover2000/n-42-25.sid
>> Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
>> Files: ./GeoCover2000/n-42-25.sid
>> Size is 51078, 39090
>> Coordinate System is `'
>> Origin = (136066.125000000000000,3323577.375000000000000)
>> Pixel Size = (14.250000000000000,-14.250000000000000)
>> Corner Coordinates:
>> Upper Left  (  136066.125, 3323577.375)
>> Lower Left  (  136066.125, 2766544.875)
>> Upper Right (  863927.625, 3323577.375)
>> Lower Right (  863927.625, 2766544.875)
>> Center      (  499996.875, 3045061.125)
>> Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
>>   Minimum=0.000, Maximum=226.000, Mean=109.610, StdDev=39.202
>>   Overviews: 25539x19545, 12770x9773, 6385x4887, 3193x2444, 1597x1222,
>> 799x611, 400x306, 200x153
>> Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
>>   Minimum=0.000, Maximum=229.000, Mean=125.833, StdDev=31.828
>> Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
>>   Minimum=0.000, Maximum=227.000, Mean=107.092, StdDev=37.230
>> $ cat ./GeoCover2000/n-42-25.prj
>> Projection     UTM
>> Datum          WGS84
>> Zunits         NO
>> Units          METERS
>> Zone           42
>> Xshift         0.000000
>> Yshift         0.000000
>> Parameters
>> Perl snippet:
>>     foreach my $sid (@files) {
>>         next unless $wanted && $sid =~ /$wanted/i;
>>         if (! -r $sid) {
>>             warn "SKIPPING: $sid is not readable!\n";
>>             next;
>>         my $gdalinfo = `gdalinfo -nomd $sid`;
>>         # parse out the strings that we need
>>         $gdalinfo =~ /Upper Left  \((\s*[^,]+),\s*([^\)]+)/s || warn
>> "Upper Left parse error\n";
>>         my $ul = [$1, $2];
>>         $gdalinfo =~ /Lower Left  \((\s*[^,]+),\s*([^\)]+)/s || warn
>> "Lower Left parse error\n";
>>         my $ll = [$1, $2];
>>         $gdalinfo =~ /Upper Right \((\s*[^,]+),\s*([^\)]+)/s || warn
>> "Upper Right error\n";
>>         my $ur = [$1, $2];
>>         $gdalinfo =~ /Lower Right \((\s*[^,]+),\s*([^\)]+)/s || warn
>> "Lower Right error\n";
>>         my $lr = [$1, $2];
>>         my $outf = $sid;
>>         $outf =~ s/\.sid//;
>>         $outf =~ m/\/([^\/]+)$/;
>>         $outf = $1;
>>         my $prj = $sid;
>>         $prj =~ s/\.sid/.prj/;
>>         if (! -r $prj) {
>>             warn "SKIPPING: $prj is not readable!\n";
>>             next;
>>         my $projinfo = `grep Zone $prj`;
>>         if ($projinfo =~ /^Zone\s*([-+]?\d+)/) {
>>             my $znum = $1;
>>             if ($znum < 0) {
>>                 $epsg = 32700 - $znum;
>>             } else {
>>                 $epsg = 32600 + $znum;
>>         else {
>>             warn "SKIPPING:  could not find zone or epsg in $prj\n";
>>             next;
>>         my $proj = sprintf("+init=epsg:%d", $epsg);
>>         print "Using projection: $proj for $projinfo" if $DEBUG;
>>         my $pj = Geo::Proj4->new($proj);
>>         if (! $pj) {
>>             warn "SKIPPING: Geo::Proj4 error: " . Geo::Proj4->error .
>> "\n";
>>             next;
>>         $ul = [reverse $pj->inverse(@$ul)];
>>         $ll = [reverse $pj->inverse(@$ll)];
>>         $ur = [reverse $pj->inverse(@$ur)];
>>         $lr = [reverse $pj->inverse(@$lr)];
>>         # this is probably a parallelgram in latlong
>>         if ($DEBUG) {
>>             printf("ul = %11.6f, %11.6f\n", @$ul);
>>             printf("ll = %11.6f, %11.6f\n", @$ll);
>>             printf("ur = %11.6f, %11.6f\n", @$ur);
>>             printf("lr = %11.6f, %11.6f\n", @$lr);
>>         # Get the bbox of the parallelgram
>>         my $xmin = $ul->[0]<$ll->[0]?$ul->[0]:$ll->[0];
>>         my $xmax = $ur->[0]>$lr->[0]?$ur->[0]:$lr->[0];
>>         my $ymin = $ll->[1]<$lr->[1]?$ll->[1]:$lr->[1];
>>         my $ymax = $ul->[1]>$ur->[1]?$ul->[1]:$ur->[1];
>>         my $tiled = '-co "TILED=YES"';
>>         $tiled = '' if -e $outf;
>>         my $nparts = 2;
>>         my $dx = ($xmax - $xmin) / $nparts;
>>         my $dy = ($ymax - $ymin) / $nparts;
>>         my ($x0, $x1, $y0, $y1);
>>         for (my $i=0, $x0=$xmin; $i<$nparts; $i++, $x0 += $dx) {
>>             $x1 = $x0 + $dx;
>>             for (my $j=0, $y0=$ymin; $j<$nparts; $j++, $y0 += $dy) {
>>                 $y1 = $y0 + $dy;
>>                 my $tif = sprintf("%s/%s/%s_%d-%d.tif", $work, $outd,
>> $outf, $i, $j);
>>                 my $cmd = sprintf("gdalwarp -srcnodata 0 -dstnodata 0
>> -s_srs +init=epsg:%d -t_srs EPSG:4326 -te $x0 $y0 $x1 $y1 -rb -wm 250
>> --config GDAL_ONE_BIG_READ ON $tiled $sid $tif\n", $epsg);
>>                 print "$cmd\n";
>>                 my $rc = system($cmd);
>>                 print "SYSTEM returned: " . sprintf("%lx\n", ($rc &
>> 0xffff))
>>                     if $DEBUG
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
