[gdal-dev] gdal create tif, errors with gdaladdo
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 19 21:14:45 EDT 2009
Even,
I ran gdalinfo -checksum on all 51GB of images and none of them reported
any errors. And none of the images are compressed.
I'm using Debian Lenny packages. There is an ldd output below.
$ uname -a
Linux mappy 2.6.23-1-amd64 #1 SMP Fri Oct 12 23:45:48 UTC 2007 x86_64
GNU/Linux
$ gdalinfo --version
GDAL 1.5.2, released 2008/05/29
$ apt-cache show libtiff4
Package: libtiff4
Priority: optional
Section: libs
Installed-Size: 484
Maintainer: Jay Berkenbilt <qjb at debian.org>
Architecture: amd64
Source: tiff
Version: 3.8.2-11
Depends: libc6 (>= 2.7-1), libjpeg62, zlib1g (>= 1:1.1.4)
Filename: pool/main/t/tiff/libtiff4_3.8.2-11_amd64.deb
MD5sum: 8c0019eef3a752760dca8f14c80c3820
SHA1: 3af8b1abde23f8b55eb840ff874cd0839d340e0f
SHA256: e6d69f5e619e97bea1513f080750dc847eab04ef7f3eb9dc26985b2e2f3bcb56
Description: Tag Image File Format (TIFF) library
  libtiff is a library providing support for the Tag Image File Format
  (TIFF), a widely used format for storing image data.  This package
  includes the shared library.
Homepage: http://libtiff.maptools.org
Tag: role::shared-lib, works-with::image:raster
A typical gdalinfo on one of the files is:
$ gdalinfo -checksum n-41-25_0-0.tif
Files: n-41-25_0-0.tif
Size is 27192, 18091
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.2572235630016,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (59.228401534356898,27.479955940770701)
Pixel Size = (0.000138699063483,-0.000138699063483)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  59.2284015,  27.4799559) ( 59d13'42.25"E, 27d28'47.84"N)
Lower Left  (  59.2284015,  24.9707512) ( 59d13'42.25"E, 24d58'14.70"N)
Upper Right (  62.9999065,  27.4799559) ( 62d59'59.66"E, 27d28'47.84"N)
Lower Right (  62.9999065,  24.9707512) ( 62d59'59.66"E, 24d58'14.70"N)
Center      (  61.1141540,  26.2253536) ( 61d 6'50.95"E, 26d13'31.27"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
   Checksum=29566
   NoData Value=0
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
   Checksum=34905
   NoData Value=0
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
   Checksum=24337
   NoData Value=0
woodbri at mappy:/u/leaddog-200903013$ ldd /usr/bin/gdalinfo
         linux-vdso.so.1 =>  (0x00007fff937fe000)
         libgdal1.5.0.so.1 => /usr/lib/libgdal1.5.0.so.1
(0x00002ac017605000)
         libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00002ac017dd4000)
         libm.so.6 => /lib/libm.so.6 (0x00002ac0180e0000)
         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00002ac018364000)
         libc.so.6 => /lib/libc.so.6 (0x00002ac01857b000)
         libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00002ac0188ce000)
         libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00002ac018adf000)
         libodbc.so.1 => /usr/lib/libodbc.so.1 (0x00002ac018d55000)
         libodbcinst.so.1 => /usr/lib/libodbcinst.so.1 (0x00002ac018fb1000)
         libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00002ac0191be000)
         libxerces-c.so.28 => /usr/lib/libxerces-c.so.28
(0x00002ac0193e7000)
         libjasper.so.1 => /usr/lib/libjasper.so.1 (0x00002ac0199e0000)
         libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0
(0x00002ac019c3a000)
         libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x00002ac019f61000)
         libdf.so.4 => /usr/lib/libdf.so.4 (0x00002ac01a188000)
         libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x00002ac01a43a000)
         libgif.so.4 => /usr/lib/libgif.so.4 (0x00002ac01a65a000)
         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00002ac01a862000)
         libtiff.so.4 => /usr/lib/libtiff.so.4 (0x00002ac01aa85000)
         libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00002ac01ace1000)
         libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0x00002ac01af06000)
         libpq.so.5 => /usr/lib/libpq.so.5 (0x00002ac01b13c000)
         libz.so.1 => /usr/lib/libz.so.1 (0x00002ac01b360000)
         libpthread.so.0 => /lib/libpthread.so.0 (0x00002ac01b577000)
         librt.so.1 => /lib/librt.so.1 (0x00002ac01b794000)
         libdl.so.2 => /lib/libdl.so.2 (0x00002ac01b99d000)
         libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4
(0x00002ac01bba1000)
         libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15
(0x00002ac01bde0000)
         /lib64/ld-linux-x86-64.so.2 (0x00002ac0173e8000)
         libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so (0x00002ac01c1eb000)
         libltdl.so.3 => /usr/lib/libltdl.so.3 (0x00002ac01c53a000)
         libicuuc.so.38 => /usr/lib/libicuuc.so.38 (0x00002ac01c741000)
         libicudata.so.38 => /usr/lib/libicudata.so.38 (0x00002ac01ca82000)
         libproj.so.0 => /usr/lib/libproj.so.0 (0x00002ac01d759000)
         libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8 (0x00002ac01d99a000)
         libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8
(0x00002ac01dbec000)
         libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00002ac01df87000)
         libcom_err.so.2 => /lib/libcom_err.so.2 (0x00002ac01e228000)
         libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2
(0x00002ac01e42c000)
         libcrypt.so.1 => /lib/libcrypt.so.1 (0x00002ac01e658000)
         libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2
(0x00002ac01e890000)
         libidn.so.11 => /usr/lib/libidn.so.11 (0x00002ac01eada000)
         liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00002ac01ed0c000)
         libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00002ac01ef1b000)
         libnsl.so.1 => /lib/libnsl.so.1 (0x00002ac01f1ce000)
         libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00002ac01f3e6000)
         libkrb5support.so.0 => /usr/lib/libkrb5support.so.0
(0x00002ac01f60d000)
         libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00002ac01f815000)
         libresolv.so.2 => /lib/libresolv.so.2 (0x00002ac01fa17000)
         libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00002ac01fc2c000)
         libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00002ac01fe46000)
         libgpg-error.so.0 => /usr/lib/libgpg-error.so.0
(0x00002ac020056000)
         libgcrypt.so.11 => /usr/lib/libgcrypt.so.11 (0x00002ac02015a000)
Even Rouault wrote:
> Hi,
> no those warnings don't sound good at all ! The number of overviews should be
> fine too.
> Could you precise the version of GDAL you're using and if you have built with
> internal libtiff or external libtiff ?
> (Such warnings could happen with older libtiff, especially with TIFF
> compression)
> Could you just check gdalinfo -checksum file.tif on your original file before
> running gdaladdo and check that it doesn't throw similar errors ?
> Best regards,
> Even
> Le Thursday 19 March 2009 22:41:53 Stephen Woodbridge, vous avez écrit :
>> Hi,
>> I just created a bunch of tif files from a mrsid file and when I use
>> gdaladdo file.tif 2 4 8 16 32 64 128 256
>> I get over a 1000 errors like:
>> ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline 1536
>> ERROR 1: TIFFReadEncodedTile() failed.
>> ERROR 1: IReadBlock failed at X offset 12, Y offset 7
>> ERROR 1: GetBlockRef failed at X block offset 12, Y block offset 7
>> ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline 1664
>> ERROR 1: IReadBlock failed at X offset 13, Y offset 7
>> ERROR 1: GetBlockRef failed at X block offset 13, Y block offset 7
>> Is this because of the number of overviews I requested? ot something
>> else? Is it safe to ignore these?
>> -Steve
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
