[gdal-dev] gdal create tif, errors with gdaladdo
Stephen Woodbridge woodbri at swoodbridge.com
Fri Mar 20 18:25:28 EDT 2009
So is the conclusion on this issue, that Debian has old/bad? libtiff
libraries? What version libtiff do I need to make this work correctly?
Is gdal 1.5.2 a reasonable version to be running under? I would like to
stay under the package management system as much as possible.
But I also need to resolve this issue.
Thanks,
   -Steve
Stephen Woodbridge wrote:
> Even,
> I ran gdalinfo -checksum on all 51GB of images and none of them reported
> any errors. And none of the images are compressed.
> I'm using Debian Lenny packages. There is an ldd output below.
> $ uname -a
> Linux mappy 2.6.23-1-amd64 #1 SMP Fri Oct 12 23:45:48 UTC 2007 x86_64
> GNU/Linux
> $ gdalinfo --version
> GDAL 1.5.2, released 2008/05/29
> $ apt-cache show libtiff4
> Package: libtiff4
> Priority: optional
> Section: libs
> Installed-Size: 484
> Maintainer: Jay Berkenbilt <qjb at debian.org>
> Architecture: amd64
> Source: tiff
> Version: 3.8.2-11
> Depends: libc6 (>= 2.7-1), libjpeg62, zlib1g (>= 1:1.1.4)
> Filename: pool/main/t/tiff/libtiff4_3.8.2-11_amd64.deb
> MD5sum: 8c0019eef3a752760dca8f14c80c3820
> SHA1: 3af8b1abde23f8b55eb840ff874cd0839d340e0f
> SHA256: e6d69f5e619e97bea1513f080750dc847eab04ef7f3eb9dc26985b2e2f3bcb56
> Description: Tag Image File Format (TIFF) library
>  libtiff is a library providing support for the Tag Image File Format
>  (TIFF), a widely used format for storing image data.  This package
>  includes the shared library.
> Homepage: http://libtiff.maptools.org
> Tag: role::shared-lib, works-with::image:raster
> A typical gdalinfo on one of the files is:
> $ gdalinfo -checksum n-41-25_0-0.tif
> Files: n-41-25_0-0.tif
> Size is 27192, 18091
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.2572235630016,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (59.228401534356898,27.479955940770701)
> Pixel Size = (0.000138699063483,-0.000138699063483)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  59.2284015,  27.4799559) ( 59d13'42.25"E, 27d28'47.84"N)
> Lower Left  (  59.2284015,  24.9707512) ( 59d13'42.25"E, 24d58'14.70"N)
> Upper Right (  62.9999065,  27.4799559) ( 62d59'59.66"E, 27d28'47.84"N)
> Lower Right (  62.9999065,  24.9707512) ( 62d59'59.66"E, 24d58'14.70"N)
> Center      (  61.1141540,  26.2253536) ( 61d 6'50.95"E, 26d13'31.27"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>   Checksum=29566
>   NoData Value=0
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
>   Checksum=34905
>   NoData Value=0
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
>   Checksum=24337
>   NoData Value=0
> woodbri at mappy:/u/leaddog-200903013$ ldd /usr/bin/gdalinfo
>         linux-vdso.so.1 =>  (0x00007fff937fe000)
>         libgdal1.5.0.so.1 => /usr/lib/libgdal1.5.0.so.1
> (0x00002ac017605000)
>         libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00002ac017dd4000)
>         libm.so.6 => /lib/libm.so.6 (0x00002ac0180e0000)
>         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00002ac018364000)
>         libc.so.6 => /lib/libc.so.6 (0x00002ac01857b000)
>         libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00002ac0188ce000)
>         libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00002ac018adf000)
>         libodbc.so.1 => /usr/lib/libodbc.so.1 (0x00002ac018d55000)
>         libodbcinst.so.1 => /usr/lib/libodbcinst.so.1 (0x00002ac018fb1000)
>         libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00002ac0191be000)
>         libxerces-c.so.28 => /usr/lib/libxerces-c.so.28
> (0x00002ac0193e7000)
>         libjasper.so.1 => /usr/lib/libjasper.so.1 (0x00002ac0199e0000)
>         libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0
> (0x00002ac019c3a000)
>         libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x00002ac019f61000)
>         libdf.so.4 => /usr/lib/libdf.so.4 (0x00002ac01a188000)
>         libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x00002ac01a43a000)
>         libgif.so.4 => /usr/lib/libgif.so.4 (0x00002ac01a65a000)
>         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00002ac01a862000)
>         libtiff.so.4 => /usr/lib/libtiff.so.4 (0x00002ac01aa85000)
>         libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00002ac01ace1000)
>         libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0x00002ac01af06000)
>         libpq.so.5 => /usr/lib/libpq.so.5 (0x00002ac01b13c000)
>         libz.so.1 => /usr/lib/libz.so.1 (0x00002ac01b360000)
>         libpthread.so.0 => /lib/libpthread.so.0 (0x00002ac01b577000)
>         librt.so.1 => /lib/librt.so.1 (0x00002ac01b794000)
>         libdl.so.2 => /lib/libdl.so.2 (0x00002ac01b99d000)
>         libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4
> (0x00002ac01bba1000)
>         libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15
> (0x00002ac01bde0000)
>         /lib64/ld-linux-x86-64.so.2 (0x00002ac0173e8000)
>         libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so (0x00002ac01c1eb000)
>         libltdl.so.3 => /usr/lib/libltdl.so.3 (0x00002ac01c53a000)
>         libicuuc.so.38 => /usr/lib/libicuuc.so.38 (0x00002ac01c741000)
>         libicudata.so.38 => /usr/lib/libicudata.so.38 (0x00002ac01ca82000)
>         libproj.so.0 => /usr/lib/libproj.so.0 (0x00002ac01d759000)
>         libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8 (0x00002ac01d99a000)
>         libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8
> (0x00002ac01dbec000)
>         libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00002ac01df87000)
>         libcom_err.so.2 => /lib/libcom_err.so.2 (0x00002ac01e228000)
>         libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2
> (0x00002ac01e42c000)
>         libcrypt.so.1 => /lib/libcrypt.so.1 (0x00002ac01e658000)
>         libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2
> (0x00002ac01e890000)
>         libidn.so.11 => /usr/lib/libidn.so.11 (0x00002ac01eada000)
>         liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00002ac01ed0c000)
>         libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00002ac01ef1b000)
>         libnsl.so.1 => /lib/libnsl.so.1 (0x00002ac01f1ce000)
>         libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00002ac01f3e6000)
>         libkrb5support.so.0 => /usr/lib/libkrb5support.so.0
> (0x00002ac01f60d000)
>         libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00002ac01f815000)
>         libresolv.so.2 => /lib/libresolv.so.2 (0x00002ac01fa17000)
>         libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00002ac01fc2c000)
>         libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00002ac01fe46000)
>         libgpg-error.so.0 => /usr/lib/libgpg-error.so.0
> (0x00002ac020056000)
>         libgcrypt.so.11 => /usr/lib/libgcrypt.so.11 (0x00002ac02015a000)
> Even Rouault wrote:
>> Hi,
>> no those warnings don't sound good at all ! The number of overviews
>> should be fine too.
>> Could you precise the version of GDAL you're using and if you have
>> built with internal libtiff or external libtiff ?
>> (Such warnings could happen with older libtiff, especially with TIFF
>> compression)
>> Could you just check gdalinfo -checksum file.tif on your original file
>> before running gdaladdo and check that it doesn't throw similar errors ?
>> Best regards,
>> Even
>> Le Thursday 19 March 2009 22:41:53 Stephen Woodbridge, vous avez écrit :
>>> Hi,
>>> I just created a bunch of tif files from a mrsid file and when I use
>>> gdaladdo file.tif 2 4 8 16 32 64 128 256
>>> I get over a 1000 errors like:
>>> ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline
>>> 1536
>>> ERROR 1: TIFFReadEncodedTile() failed.
>>> ERROR 1: IReadBlock failed at X offset 12, Y offset 7
>>> ERROR 1: GetBlockRef failed at X block offset 12, Y block offset 7
>>> 1664
>>> ERROR 1: IReadBlock failed at X offset 13, Y offset 7
>>> ERROR 1: GetBlockRef failed at X block offset 13, Y block offset 7
>>> Is this because of the number of overviews I requested? ot something
>>> else? Is it safe to ignore these?
>>> -Steve
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
