[gdal-dev] gdal create tif, errors with gdaladdo
Even Rouault even.rouault at mines-paris.org
Fri Mar 20 17:24:10 EDT 2009
Stephen,
I've managed to reproduce your issue with GDAL 1.5 compiled with libtiff 3.8.2
(and I'm not so surprised, as I remember that it was a known issue). But when
built with internal libtiff or against external libtiff 3.9.0 (CVS head
version), it works fine. So it is due to some bug in libtiff 3.8.2.
So you could either compile GDAL with internal libtiff support, or just build
libtiff 3.9.0 and trick GDAL to link against it by using LD_LIBRARY_PATH.
You'll need to create a symlink from the generated libtiff.so to libtiff.so.4
which is expected by the Debian libgdal.so. I've tried that and it works
fine.
Best regards,
Even
Le Friday 20 March 2009 04:43:39 Stephen Woodbridge, vous avez écrit :
> Even,
> So I just happened to have made a backup copy of the tif files before
> adding the overviews. And as a said, all the files without overviews did
> not report errors with gdalinfo -checksum file.tif.  I also check all
> the files with the overviews and some of them, not all, do report
> errors. I'm seeing reported:
> Warning 1: TIFFReadDirectory:n-41-35_0-0.tif: Wrong "StripByteCounts"
> field, ignoring and calculating from imagelength
> on some of the files that have overviews added. I went back and checked
> output from the gdaladdo and it shows up in places there also.
> This is the file without overviews added:
> woodbri at mappy:/u/leaddog-200903013/af-bck$ gdalinfo -checksum
> n-41-35_0-0.tif
> Driver: GTiff/GeoTIFF
> Files: n-41-35_0-0.tif
> Size is 26688, 16853
> Coordinate System is:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.2572235630016,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0],
>      UNIT["degree",0.0174532925199433],
>      AUTHORITY["EPSG","4326"]]
> Origin = (59.025339626823701,37.469898080618897)
> Pixel Size = (0.000148923698721,-0.000148923698721)
> Metadata:
>    AREA_OR_POINT=Area
> Image Structure Metadata:
>    INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  59.0253396,  37.4698981) ( 59d 1'31.22"E, 37d28'11.63"N)
> Lower Left  (  59.0253396,  34.9600870) ( 59d 1'31.22"E, 34d57'36.31"N)
> Upper Right (  62.9998153,  37.4698981) ( 62d59'59.34"E, 37d28'11.63"N)
> Lower Right (  62.9998153,  34.9600870) ( 62d59'59.34"E, 34d57'36.31"N)
> Center      (  61.0125775,  36.2149925) ( 61d 0'45.28"E, 36d12'53.97"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>    Checksum=4400
>    NoData Value=0
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
>    Checksum=18333
>    NoData Value=0
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
>    Checksum=64262
>    NoData Value=0
> And here is the samefile after adding the overviews:
> woodbri at mappy:/u/leaddog-200903013/af-bck$ cd ../af
> woodbri at mappy:/u/leaddog-200903013/af$ gdalinfo -checksum n-41-35_0-0.tif
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
> Metadata:
>    AREA_OR_POINT=Area
>    INTERLEAVE=PIXEL
> Corner Coordinates:
>    Checksum=4400
>    NoData Value=0
>    Overviews: 13344x8427, 6672x4214, 3336x2107, 1668x1054, 834x527,
> 417x264, 209x132, 105x66
>    Checksum=18333
>    NoData Value=0
>    Checksum=64262
>    NoData Value=0
> Stephen Woodbridge wrote:
> > Even,
> > I ran gdalinfo -checksum on all 51GB of images and none of them reported
> > any errors. And none of the images are compressed.
> > I'm using Debian Lenny packages. There is an ldd output below.
> > $ uname -a
> > Linux mappy 2.6.23-1-amd64 #1 SMP Fri Oct 12 23:45:48 UTC 2007 x86_64
> > GNU/Linux
> > $ gdalinfo --version
> > GDAL 1.5.2, released 2008/05/29
> > $ apt-cache show libtiff4
> > Package: libtiff4
> > Priority: optional
> > Section: libs
> > Installed-Size: 484
> > Maintainer: Jay Berkenbilt <qjb at debian.org>
> > Architecture: amd64
> > Source: tiff
> > Version: 3.8.2-11
> > Depends: libc6 (>= 2.7-1), libjpeg62, zlib1g (>= 1:1.1.4)
> > Filename: pool/main/t/tiff/libtiff4_3.8.2-11_amd64.deb
> > MD5sum: 8c0019eef3a752760dca8f14c80c3820
> > SHA1: 3af8b1abde23f8b55eb840ff874cd0839d340e0f
> > SHA256: e6d69f5e619e97bea1513f080750dc847eab04ef7f3eb9dc26985b2e2f3bcb56
> > Description: Tag Image File Format (TIFF) library
> >  libtiff is a library providing support for the Tag Image File Format
> >  (TIFF), a widely used format for storing image data.  This package
> >  includes the shared library.
> > Homepage: http://libtiff.maptools.org
> > Tag: role::shared-lib, works-with::image:raster
> > A typical gdalinfo on one of the files is:
> > $ gdalinfo -checksum n-41-25_0-0.tif
> > Files: n-41-25_0-0.tif
> > Size is 27192, 18091
> > GEOGCS["WGS 84",
> >     DATUM["WGS_1984",
> > Origin = (59.228401534356898,27.479955940770701)
> > Pixel Size = (0.000138699063483,-0.000138699063483)
> > Metadata:
> >   AREA_OR_POINT=Area
> >   INTERLEAVE=PIXEL
> > Corner Coordinates:
> > Upper Left  (  59.2284015,  27.4799559) ( 59d13'42.25"E, 27d28'47.84"N)
> > Lower Left  (  59.2284015,  24.9707512) ( 59d13'42.25"E, 24d58'14.70"N)
> > Upper Right (  62.9999065,  27.4799559) ( 62d59'59.66"E, 27d28'47.84"N)
> > Lower Right (  62.9999065,  24.9707512) ( 62d59'59.66"E, 24d58'14.70"N)
> > Center      (  61.1141540,  26.2253536) ( 61d 6'50.95"E, 26d13'31.27"N)
> >   Checksum=29566
> >   NoData Value=0
> >   Checksum=34905
> >   NoData Value=0
> >   Checksum=24337
> >   NoData Value=0
> > woodbri at mappy:/u/leaddog-200903013$ ldd /usr/bin/gdalinfo
> >         linux-vdso.so.1 =>  (0x00007fff937fe000)
> >         libgdal1.5.0.so.1 => /usr/lib/libgdal1.5.0.so.1
> > (0x00002ac017605000)
> >         libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00002ac017dd4000)
> >         libm.so.6 => /lib/libm.so.6 (0x00002ac0180e0000)
> >         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00002ac018364000)
> >         libc.so.6 => /lib/libc.so.6 (0x00002ac01857b000)
> >         libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00002ac0188ce000)
> >         libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00002ac018adf000)
> >         libodbc.so.1 => /usr/lib/libodbc.so.1 (0x00002ac018d55000)
> >         libodbcinst.so.1 => /usr/lib/libodbcinst.so.1
> > (0x00002ac018fb1000) libexpat.so.1 => /usr/lib/libexpat.so.1
> > (0x00002ac0191be000) libxerces-c.so.28 => /usr/lib/libxerces-c.so.28
> > (0x00002ac0193e7000)
> >         libjasper.so.1 => /usr/lib/libjasper.so.1 (0x00002ac0199e0000)
> >         libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0
> > (0x00002ac019c3a000)
> >         libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x00002ac019f61000)
> >         libdf.so.4 => /usr/lib/libdf.so.4 (0x00002ac01a188000)
> >         libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x00002ac01a43a000)
> >         libgif.so.4 => /usr/lib/libgif.so.4 (0x00002ac01a65a000)
> >         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00002ac01a862000)
> >         libtiff.so.4 => /usr/lib/libtiff.so.4 (0x00002ac01aa85000)
> >         libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00002ac01ace1000)
> >         libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0x00002ac01af06000)
> >         libpq.so.5 => /usr/lib/libpq.so.5 (0x00002ac01b13c000)
> >         libz.so.1 => /usr/lib/libz.so.1 (0x00002ac01b360000)
> >         libpthread.so.0 => /lib/libpthread.so.0 (0x00002ac01b577000)
> >         librt.so.1 => /lib/librt.so.1 (0x00002ac01b794000)
> >         libdl.so.2 => /lib/libdl.so.2 (0x00002ac01b99d000)
> >         libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4
> > (0x00002ac01bba1000)
> >         libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15
> > (0x00002ac01bde0000)
> >         /lib64/ld-linux-x86-64.so.2 (0x00002ac0173e8000)
> >         libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so
> > (0x00002ac01c1eb000) libltdl.so.3 => /usr/lib/libltdl.so.3
> > (0x00002ac01c53a000) libicuuc.so.38 => /usr/lib/libicuuc.so.38
> > (0x00002ac01c741000) libicudata.so.38 => /usr/lib/libicudata.so.38
> > (0x00002ac01ca82000) libproj.so.0 => /usr/lib/libproj.so.0
> > (0x00002ac01d759000) libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8
> > (0x00002ac01d99a000) libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8
> > (0x00002ac01dbec000)
> >         libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00002ac01df87000)
> >         libcom_err.so.2 => /lib/libcom_err.so.2 (0x00002ac01e228000)
> >         libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2
> > (0x00002ac01e42c000)
> >         libcrypt.so.1 => /lib/libcrypt.so.1 (0x00002ac01e658000)
> >         libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2
> > (0x00002ac01e890000)
> >         libidn.so.11 => /usr/lib/libidn.so.11 (0x00002ac01eada000)
> >         liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2
> > (0x00002ac01ed0c000) libgnutls.so.26 => /usr/lib/libgnutls.so.26
> > (0x00002ac01ef1b000) libnsl.so.1 => /lib/libnsl.so.1 (0x00002ac01f1ce000)
> >         libk5crypto.so.3 => /usr/lib/libk5crypto.so.3
> > (0x00002ac01f3e6000) libkrb5support.so.0 => /usr/lib/libkrb5support.so.0
> > (0x00002ac01f60d000)
> >         libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00002ac01f815000)
> >         libresolv.so.2 => /lib/libresolv.so.2 (0x00002ac01fa17000)
> >         libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00002ac01fc2c000)
> >         libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00002ac01fe46000)
> >         libgpg-error.so.0 => /usr/lib/libgpg-error.so.0
> > (0x00002ac020056000)
> >         libgcrypt.so.11 => /usr/lib/libgcrypt.so.11 (0x00002ac02015a000)
> > Even Rouault wrote:
> >> Hi,
> >> no those warnings don't sound good at all ! The number of overviews
> >> should be fine too.
> >> Could you precise the version of GDAL you're using and if you have
> >> built with internal libtiff or external libtiff ?
> >> (Such warnings could happen with older libtiff, especially with TIFF
> >> compression)
> >> Could you just check gdalinfo -checksum file.tif on your original file
> >> before running gdaladdo and check that it doesn't throw similar errors ?
> >> Best regards,
> >> Even
> >> Le Thursday 19 March 2009 22:41:53 Stephen Woodbridge, vous avez écrit :
> >>> Hi,
> >>> I just created a bunch of tif files from a mrsid file and when I use
> >>> gdaladdo file.tif 2 4 8 16 32 64 128 256
> >>> I get over a 1000 errors like:
> >>> ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline
> >>> 1536
> >>> ERROR 1: TIFFReadEncodedTile() failed.
> >>> ERROR 1: IReadBlock failed at X offset 12, Y offset 7
> >>> ERROR 1: GetBlockRef failed at X block offset 12, Y block offset 7
> >>> 1664
> >>> ERROR 1: IReadBlock failed at X offset 13, Y offset 7
> >>> ERROR 1: GetBlockRef failed at X block offset 13, Y block offset 7
> >>> Is this because of the number of overviews I requested? ot something
> >>> else? Is it safe to ignore these?
> >>> -Steve
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
