[gdal-dev] again .hdf to .tif
Vincent Schut schut at sarvision.nl
Thu Mar 26 11:25:05 EDT 2009
Yann Chemin wrote:
> Hi there,
> I am using this one right now on Level 2 and 3 MODIS products
> #!/bin/bash
> mkdir processed
> for file in *.hdf
> do SDS_list=$(gdalinfo $file | grep "SUBDATASET_.*_NAME.*")
> 	for subdataset in $SDS_list
> 	do echo ${subdataset#*=} > tempfile.txt
> 	out=$(sed 's/\(.*\):\(.*\):"\(.*\).A\(.*\)\.\h\(.*\)\.\(.*\)\.\(.*\).hdf":\(.*\):\(.*\)/\3\_\4\_h\5\_\8\_\9\.tif/'
> tempfile.txt)
> 	gdalwarp -of GTiff -t_srs EPSG:4326 ${subdataset#*=} processed/$out
> 	done
> done
> maybe of help,
> Yann
Note that, when you are using modis sinusoidal projected hdf products,
you might have to use something like this to prevent a shift in the y
direction which becomes more pronounced when further from the equator:
gdalwarp -s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null +wktext'
-t_srs EPSG:4326 <hdf> <out.tif>
to force gdalwarp to adjust for the custom ellipsoid that the modis
sinusoidal projection uses. Or, at least, I had to some time ago. It
might have been 'fixed' already.
Regards,
Vincent.
> 2009/3/26 Anja Roesel <anja.roesel at zmaw.de>:
>> sorry i forgot to mention the error message:
>>> Segmentation fault
>> Hi list,
>> I am trying to convert MODIS .hdf files to .tif files (it worked with
>> ASTER files earlier, thats why I am now really curious).
>> i typed
>>> gdalinfo MOD021KM.A2008134.1935.005.2009071201911.hdf
>> result:
>> SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"MOD021KM.A2008134.1935.005.2009071201911.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB
>> SUBDATASET_1_DESC=[15x2030x1354] EV_1KM_RefSB (16-bit unsigned integer)
>> SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"MOD021KM.A2008134.1935.005.2009071201911.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB_Uncert_Indexes
>> SUBDATASET_2_DESC=
>> then:
>>> gdalwarp
>>  modis.tif
>> Have you any ideas, what is the problem?
>> Thanks,
>> Anja
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
