[gdal-dev] Re: prj to proj.4
Hermann Peifer peifer at gmx.eu
Thu Mar 26 11:35:42 EDT 2009
Brent Wood wrote:
> Hermann,
> This might work for you, although far from elegant :-)
> If you generate a GMT file (using ogr2ogr) of each of the shapefiles, & just grep out the relevant lines from each file (@Jp is the proj.4 text, @Jw is the WKT version), it should give you both the WKT & proj.4 versions of the projection, (or just grep "@Jp" for the proj one); eg, ...
This is actually what I am doing already as a workaround (I mentioned
this in my first mail). I just do it inside a small bash/AWK script,
which says somewhere in the middle:
 if ( /^# @Jp/ )
       proj = substr($0, 6)
Just to finish the story with the Rob's Python script:
With the helpful hints from the list I got around the initial problems,
which mainly originate from the fact that I am not root on the target
system. I was able to import osr, but then libgdal.so.1 was claimed to
be missing (it is there, in $HOME/lib, but this is probably not where it
is expected to be). Then there was the need for changing the PYTHONPATH,
which I can do for myself, but not for the account under which the
script is expected to run later...
To make a long story short: I will have to convince the system admin to
provide a more sustainable fix of these issues and until I have his
willingness to do so, I will simply continue with my tmp.gmt workaround.
Thanks for the support. It will just take some time before I can benefit
from it.
Hermann
