[gdal-dev] Coordinate bounds after gdalwarp
Martin Ceperley martin at ceperley.com
Thu Mar 26 23:57:36 EDT 2009
Hello,
After running gdalwarp with a bunch of control points, the resulting
bitmap's coordinate bounds are slightly cropping off two of the
corners and extending far beyond on the right. I am referencing these
images for the first time and don't have the necessary bounds before
the transformation.
Here is a low-res example: http://ceperley.com/temp/OUT.jpg
Any flags to correct this within gdalwarp or gdal_transform? Or do any
of other command line tools generate projected corner coordinates?
Thanks -Martin
