[gdal-dev] ogr 1.6 and ArcSDE 9.3sp1: not reading varchar2 fields
Duarte Carreira DCarreira at edia.pt
Sat Mar 28 17:00:36 EDT 2009
Mike,
That's a good idea, but not really well accepted in many cases...
In my particular case I ended up changing my tables to varchar2...
We'll have to wait for unicode support in ogr.
Thanks,
Duarte
________________________________________
De: Michael Smith [michael.smith at usace.army.mil]
Enviado: sexta-feira, 27 de Março de 2009 10:22
Para: Duarte Carreira; gdal-dev at lists.osgeo.org
Assunto: Re: [gdal-dev] ogr 1.6 and ArcSDE 9.3sp1: not reading varchar2 fields
Duarte,
Why not create a view that has the TRANSLATE and TO_CHAR and then use that
in OGR.
Mike
Michael Smith
RSGIS Center
ERDC - CRREL
US Army Corps of Engineers
On 3/27/09  5:44 AM, "Duarte Carreira" <DCarreira at edia.pt> wrote:
> I'm correcting the subject of the message - the problem is with NVARCHAR
> fields (not varchar2).
> It seems this relates to utf issues/limitations in ogr.
> If I could use SQL functions this could be solved by the database itself. Like
> using TO_CHAR(field_name) or TRANSLATE(field_name USING CS_CHAR). But it seems
> ogr does not support these sql functions/operators...
> Any additional suggestions?
> Thanks,
> Duarte
> -----Mensagem original-----
> De: Duarte Carreira [mailto:DCarreira at edia.pt]
> Enviada: quinta-feira, 26 de Março de 2009 23:54
> Para: gdal-dev at lists.osgeo.org
> Assunto: [gdal-dev] ogr 1.6 and ArcSDE 9.3sp1: not reading varchar2 fields
> Hello.
> As always trying to coerce these two to work together nicely...
> The situation: exporting ArcSDE feature class to <anything>, shapefile, gpx...
> server: Oracle xe (10), ArcSDE 9.3 sp1, Win2003 Std x32
> client: Vista x32, GDAL/OGR 1.6 build 1500 from Tamas site, sde dll's from 9.3
> sp1
> As you can see below, Oracle describes several fields as being number and
> nvarchar2, and ogrinfo only identifies numeric fields. All text fields come
> out as unknown.
> Now, what could this be due to? Anyone facing the same issue? I tried to use
> SQL to cast a nvarchar to character without success...
> Thanks,
> Duarte
> Feature class description in Oracle:
> Column Name     Data Type       Nullable        Default Primary Key
> OBJECTID        NUMBER  No      -       -
> IDPERC  NVARCHAR2(6)    Yes     -       -
> NOME    NVARCHAR2(150)  Yes     -       -
> DESCRICAO       NVARCHAR2(255)  Yes     -       -
> IDPONTO NVARCHAR2(10)   Yes     -       -
> IDSIG   NUMBER  Yes     -       -
> XCOORD  NUMBER(38,8)    Yes     -       -
> YCOORD  NUMBER(38,8)    Yes     -       -
> MORADA_COMPLETA NVARCHAR2(255)  Yes     -       -
> CONCELHO        NVARCHAR2(50)   Yes     -       -
> FREGUESIA       NVARCHAR2(50)   Yes     -       -
> CODPOSTAL       NVARCHAR2(10)   Yes     -       -
> TELEFONE        NVARCHAR2(10)   Yes     -       -
> DESCRICAOPT     NVARCHAR2(255)  Yes     -       -
> NOMEPT  NVARCHAR2(150)  Yes     -       -
> SHAPE   ST_GEOMETRY     Yes     -       -
>                 1 - 16
> ogrinfo output:
> Layer name: <user>.<table>
> Geometry: Unknown (any)
> ERROR 1: SE_layer_get_statistics: -51/Underlying DBMS error
> Feature Count: -1
> Extent: (6177.862000, -123296.045000) - (63997.354000, -91245.397000)
> Layer SRS WKT:
> PROJCS["Datum_73_Hayford_Gauss_IPCC",
>     GEOGCS["GCS_Datum_73",
>         DATUM["Datum_73",
>             SPHEROID["International_1924",6378388.0,297.0]],
>         PRIMEM["Greenwich",0.0],
>         UNIT["Degree",0.0174532925199433]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["False_Easting",180.598],
>     PARAMETER["False_Northing",-86.99],
>     PARAMETER["Central_Meridian",-8.131906111111112],
>     PARAMETER["Scale_Factor",1.0],
>     PARAMETER["Latitude_Of_Origin",39.66666666666666],
>     UNIT["Meter",1.0]]
> OBJECTID: Integer (10.0)
> IDPERC: (unknown) (6.0)
> NOME: (unknown) (50.0)
> DESCRICAO: (unknown) (50.0)
> IDLINHA: (unknown) (5.0)
> SHAPE_LENG: Real (38.8)
> gdal-dev mailing list
