[gdal-dev] ERROR 4: `AOI.tif' not recognised as a supported file format.
Oz Nahum nahumoz at gmail.com
Mon Mar 30 11:25:13 EDT 2009
I have encountered a weired problem with gdal_rasterize.
when I run the script from here
http://trac.osgeo.org/gdal/wiki/FAQRaster#HowcanIcreateablankrasterbasedonavectorfilesextentsforusewithgdal_rasterize
When I run:
#!/usr/bin/env python
from osgeo import gdal
from osgeo import osr
from osgeo import ogr
import numpy
#from numpy import ones
import stat, sys, os, string, commands
shp = 'AOI'
tiff = 'AOI.tif'
px = 1
tiff_width = 80
tiff_height = 80
# Import vector shapefile
vector = ogr.GetDriverByName('ESRI Shapefile')
src_ds = vector.Open(shp +'.shp')
src_lyr = src_ds.GetLayerByIndex(index=0)
src_extent = src_lyr.GetExtent()
# Create new raster layer with 4 bands
raster = gdal.GetDriverByName('GTiff')
dst_ds = raster.Create( tiff, tiff_width, tiff_height, 1, gdal.GDT_Byte)
# Create raster GeoTransform based on upper left corner and pixel resolution
raster_transform = [src_extent[0], px, 0.0, src_extent[3], 0.0, -px]
dst_ds.SetGeoTransform( raster_transform )
# Get projection of shapefile and assigned to raster
srs = osr.SpatialReference()
srs.ImportFromWkt(src_lyr.GetSpatialRef().__str__())
dst_ds.SetProjection( srs.ExportToWkt() )
# Create blank raster with fully opaque alpha band
zeros = numpy.zeros( (tiff_height, tiff_width), numpy.uint8 )
dst_ds.GetRasterBand(1).WriteArray( zeros )
commandString =  'gdal_rasterize -burn 255 -l AOI AOI.shp AOI.tif'
commandOutput = commands.getoutput(commandString)
print commandOutput
#end of code
I get the error this error:
augmented to the gdal_rasterize command I see this error. When I run it via
a shell script, I don't see the error:
#!/bin/sh
python create_empty_raster.py
Runs ok.
So I am confused, why I can't call gdal_rasterize from python ?
Thanks, for any help
Oz Nahum
Universtät Tuebingen
Applied Environmental Sciences
           Imagine there's no countries
           It isn't hard to do
           Nothing to kill or die for
           And no religion too
           Imagine all the people
           Living life in peace
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090330/b14d5eaf/attachment.html
