[gdal-dev] ERROR 4: `AOI.tif' not recognised as a supported file format.
Oz Nahum nahumoz at gmail.com
Mon Mar 30 15:21:58 EDT 2009
thanks,
That does the trick.
Oz.
On Mon, Mar 30, 2009 at 7:02 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Oz,
> See the hereafter a correction to insert in your code that will hopefully
> fix
> your issue.
> Le Monday 30 March 2009 17:25:13 Oz Nahum, vous avez écrit :
> > Hi,
> > I have encountered a weired problem with gdal_rasterize.
> > when I run the script from here
> http://trac.osgeo.org/gdal/wiki/FAQRaster#HowcanIcreateablankrasterbasedona
> >vectorfilesextentsforusewithgdal_rasterize
> > When I run:
> > #!/usr/bin/env python
> > from osgeo import gdal
> > from osgeo import osr
> > from osgeo import ogr
> > import numpy
> > #from numpy import ones
> > import stat, sys, os, string, commands
> > shp = 'AOI'
> > tiff = 'AOI.tif'
> > px = 1
> > tiff_width = 80
> > tiff_height = 80
> > # Import vector shapefile
> > vector = ogr.GetDriverByName('ESRI Shapefile')
> > src_ds = vector.Open(shp +'.shp')
> > src_lyr = src_ds.GetLayerByIndex(index=0)
> > src_extent = src_lyr.GetExtent()
> > # Create new raster layer with 4 bands
> > raster = gdal.GetDriverByName('GTiff')
> > dst_ds = raster.Create( tiff, tiff_width, tiff_height, 1, gdal.GDT_Byte)
> > # Create raster GeoTransform based on upper left corner and pixel
> > resolution raster_transform = [src_extent[0], px, 0.0, src_extent[3],
> 0.0,
> > -px] dst_ds.SetGeoTransform( raster_transform )
> > # Get projection of shapefile and assigned to raster
> > srs = osr.SpatialReference()
> > srs.ImportFromWkt(src_lyr.GetSpatialRef().__str__())
> > dst_ds.SetProjection( srs.ExportToWkt() )
> > # Create blank raster with fully opaque alpha band
> > zeros = numpy.zeros( (tiff_height, tiff_width), numpy.uint8 )
> > dst_ds.GetRasterBand(1).WriteArray( zeros )
> # Properly close the dataset before calling gdal_rasterize, so that the TIF
> # file is properly written.
> dst_ds = None
> > commandString =  'gdal_rasterize -burn 255 -l AOI AOI.shp AOI.tif'
> > commandOutput = commands.getoutput(commandString)
> > print commandOutput
> > #end of code
> > I get the error this error:
> > augmented to the gdal_rasterize command I see this error. When I run it
> via
> > a shell script, I don't see the error:
> > #!/bin/sh
> > python create_empty_raster.py
> > Runs ok.
> --> This runs ok as at the end of the create_empty_raster.py script, the
> GDAL
> dataset is automatically closed.
> > So I am confused, why I can't call gdal_rasterize from python ?
> > Thanks, for any help
> > Oz Nahum
> > Universtät Tuebingen
> > Applied Environmental Sciences
           Imagine there's no countries
           It isn't hard to do
           Nothing to kill or die for
           And no religion too
           Imagine all the people
           Living life in peace
          You all must read 'The God Delusion'
          http://en.wikipedia.org/wiki/The_God_Delusion
when one person suffers from a delusion it is called insanity. When many
people suffer from a delusion it is called religion."
Robert Pirsig, Zen and the Art of Motorcycle Maintenance
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090330/95da968c/attachment.html
