[gdal-dev] How to use GDAL Library
Ajmeri Iqbal isajmeri at rediffmail.com
Tue Mar 31 02:01:51 EDT 2009
Thanks Jürgen.i recoded with C-api and working fine.but now i have confusion about functionality of C-api and C++-api.shell i continue with C-api or build GDAL library with MinGW and use C++-api?On Mon, 30 Mar 2009 15:55:18 +0200 Jürgen E. Fischer wroteHi,On Mon, 30. Mar 2009 at 13:22:46 -0000, Ajmeri Iqbal wrote:> D:/QT_Projects/ImageRW/main.cpp:34:   reference to> `GDALDataset::GetRasterCount()'Are you using the C++ API directly? That won't work from MinGW unlessGDAL is also built with MinGW. The C-API will work.Jürgen-- Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50Software Engineer D-26506 Norden http://www.norbit.de-- norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbHRheinstrasse 13, 26506 NordenGF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502_______________________________________________gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090331/4408d64c/attachment.html
