[gdal-dev] in memory KML
Tue Mar 31 13:32:31 EDT 2009
Clay, Bruce wrote:
> After a bit more digging I am not sure I asked the right question.
> What I want to do is read feature information from a shapefile or other
> data source and get a string that contains the feature information
> encoded in KML that I can pass directly into Google Earth.  I know I can
> do this operation is I open the shapefile write the KML data to disk
> then open the kml file up with fopen then read it into memory and send
> it t Google Earth but I would like to save the disk write the read
> operation.
> Any thoughts?
Bruce,
I've skimmed the KML driver and there is no sign that it uses the VSI*L
API for file access, so I don't see any way you can write results to a
memory buffer without substantial recoding in the kml driver.
Best regards,
