[gdal-dev] Questions about projects of GSoC 2009
Klokan Petr Přidal klokan at klokan.cz
Tue Mar 31 13:33:14 EDT 2009
Jorge,
I am glad you are interested in the PNG driver, which I suggested as a
project for Summer of Code...
It would be really great to have this in GDAL and I guess more
projects will profit from this...
I am going to assist as much as I can, whether in gsoc program
timeframe or even otherwise.
Feel free to contact me with any questions related to this project...
I guess for position of mentor there are better candidates then me
(like Frank, Even, Mateusz, ...)
Because I am a PhD student I applied in this Summer of Code as well as
a student so I technically I can not be your mentor. I can work this
summer on the WMTS implementation and other GDAL2Tiles improvements...
but I don't want to block position of new candidates...
If you are interested in WMTS implementation and GDAL2Tiles then just
go ahead, this I can mentor for sure ;-)
Best regards,
Klokan
2009/3/30 Mateusz Loskot <mateusz at loskot.net>:
> Jorge Arévalo wrote:
>> The entire process could be improved by several ways:
>> - I would like to have an enhaced PNG driver, to reduce the size of the
>> tiles. For this reason, I had a theoretical approach to NeuQuant
>> algorithm and I used pngnq. I discovered the relation between this
>> algorithm and Kohonen Neural Networks, that I studied during my degree,
>> and I liked a lot. Basically, for these reasons I'm interested in the
>> project about PNG Driver
> Nice idea.
>> - On one hand, at first I was using raster data, instead of vector data.
>> When the need of merging data arose, I had to change the point and use
>> vector data + Postgis. On the other hand, I would like to integrate my
>> layer to another ones in a bigger context, and I think that the raster
>> support on Postgis will be a really useful thing. For these reasons, I'm
>> interested in the project about WKT Raster.
> Good.
>> - Before using gdal2tiles, I made my own "map tiler", creating the tiles
>> needed "on-the-fly". As thought, it didn't work. I tried to use my own
>> "tile cache system". One problem was the low rate of cache hints. Then,
>> I discovered the WMS standard, and recently, the coming WMTS standard,
>> even better. For this reason, I'm interested in the project about WMTS
>> implementation.
> Good as well.
>> Now, this is my "minimum schedule". This is, the minimum amount of time
>> that I can use this summer. With high probability, I will be able to use
>> more time, but I prefer to put myself in the worst situation:
>> May 23 - June 30: 22h per week (total 118h)
>> July 1 - July 31: 45h per week (total 207h)
>> August 1 - August 10: 22h per week (total 26h)
> It should be more than enough.
>> Finally, I have experience with C, C++, Java and Python languages. My
>> favourite one is C. I made the most of my practice work during degree in C.
> Good.
>> Do you think, with this provisional schedule in mind, that I can apply
>> for one of the projects?
> Yes, I'm sure you are able to do it.
>> If not, would it be possible to find a mentor for one of them?
>> Without paying and GSoC deadlines, of course.
> I'm sure you can try, it won't hurt :-)
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://blog.klokan.cz/
http://www.maptiler.org/
http://www.oldmapsonline.org/
