[gdal-dev] xml file for accessing to a wcs server
Tue Mar 31 21:01:36 EDT 2009
belaqziz salwa wrote:
> Hi,
> for Accessing to a WCS server i created a local service description xml
> file,but when i
> tested the gdal_translate command, i have the following error:
> C:\Inetpub\wps>gdal_translate -of GTIFF wcs.xml wcs.tif -srcwin 0 0 547 347
> Input file size is 548, 348
> 0ERROR 1: Returned tile does not match expected band count.
> Open GDAL Datasets:
>   1 N GTiff       -1 547x347x3 /vsimem/wcs/00E2F5F0/wcsresult.dat
Salwa,
It would be helpful if you could provide the WCS service
description file, assuming the WCS service is public.
> I also tried to re-compile gdal, but i have error :
>         cd apps
>         nmake /nologo /f makefile.vc
>         cl /nologo /MD /EHsc /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG -I..\port -I..\ogr -I..\gcore
> -I..\alg -I..\ogr\ogrsf_frmts   -I..\frmts -I..\alg -I..\ogr
> -I..\ogr\ogrsf_frmts gdalinfo.c  ..\gdal_i.lib /link
> gdalinfo.c
> gdalinfo.obj : error LNK2019: unresolved external symbol
> _GDALAllRegister at 0 referenced in function _main
> gdalinfo.exe : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 8\VC\BIN\cl.EXE"' : return code '0x2'
That is odd.  I have no opinion on why it is happening.
Best regards,
