[gdal-dev] removing of transparency possible?
Tue Mar 31 21:13:19 EDT 2009
WolfgangZ wrote:
> Hi,
> how do I remove a transparency layer? I used one during the merging
> process, but conversion to jpg (e.g.) complains about.
> Many thanks
> Wolg
Wolg,
Are you referring to an alpha band?  If so, you could select a subset of
bands with gdal_translate using the -b flag.
eg.
Best regards,
