[gdal-dev] Gdal + numpy + interpolation
Nicolas B. piklas at gmail.com
Fri May 1 13:22:07 EDT 2009
Hi Wesley
I don't know about numpy
but here's an example in which a  gdal command for interpolating point .csv
values using inverse distance is called from python
the raster layer is created using vrt
*gdal_grid -a invdist:power=1.0:smoothing=50.0
-txe"+str(xmin)+str(xmax)+"-tye"*
*+str(ymin)+str(ymax)+" -of GTiff -ot Float64 -l input  input.vrt
output.tif").readlines()*
you can reach other gdal_grid interpolation techniques here
http://www.gdal.org/gdal_grid.html#gdal_grid_algorithms
i don't know if it these algorithms are still maintained
Regards
Nicolas BOZON
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090501/80d35a86/attachment.html
