[gdal-dev] ESRI Personal Geodatabase Write Access?
David Anderson da at donnellandallred.com
Wed May 6 12:08:50 EDT 2009
Does the OGR provider support write access to ESRI personal
geodatabases?  I have tried to find the answer on the web but can't
figure it out.  If not, does anyone know of another way to write to
these with Map 3D?
Thanks,
David
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090506/ce823b17/attachment.html
