[gdal-dev] GDAL 1.6.1 RC1 Released
Ivan ivan.lucena at pmldnet.com
Sat May 9 18:30:36 EDT 2009
Even, Howard,
Even Rouault wrote:
> Ivan,
> I guess you have run trunk autotest, instead of 1.6 branch autotest.
> (last test for 1.6 branch autotest is tiff_ovr_19). It is not surprising that
> you get crashes on some steps when running autotest of trunk with earlier
> GDAL version, as new test steps are introduced to test some bug fixes that
> only go into trunk.
That is probably the case.
Regards,
Ivan
