[gdal-dev] Working with overviews (in python)
Even Rouault even.rouault at mines-paris.org
Sun May 10 16:57:09 EDT 2009
As Frank said in his email, there's work needed in GDAL internals to do what
you want properly. But I've just found a workaround that might work if you
only plan to use the produced (external) overviews with GDAL. The trick is to
generate the overviews by hand with gdalwarp.
Let's say that your input file is 1024x1024 large.
Then try :
gdalwarp -rcs -ts 512 512 input.tif input.tif.ovr
gdalwarp -rcs -ts 256 256 input.tif.ovr input.tif.ovr.ovr
gdalwarp -rcs -ts 128 128 input.tif.ovr.ovr input.tif.ovr.ovr.ovr
By chance, GDAL can handle overviews of overviews...
Best regards,
Even
