[gdal-dev] gdalwarp for ED50 UTM zone 31N to WGS84
Jorge Arévalo jorge.arevalo at gmail.com
Wed May 13 18:14:35 EDT 2009
Hello,
I'm from Spain, and I can confirm your parameters. These worked for me as
well.
Regards
Jorge
On Tue, May 12, 2009 at 1:03 AM, Ragi Y. Burhum <ragi at burhum.com> wrote:
> I was just sending this e-mail so that it can be searched through the
> archives. Thanks to Even Rouault for walking me through something that
> should have been obvious :)
> Originally, I was having trouble finding the right parameters for gdalwarp
> to be able to warp some imagery that I got from Spain. These were in ED50 /
> UTM zone 31N:
> rburhum at cuzconix:~/p_bug$ gdalinfo exported_from_original_sid_file.tif
> Driver: GTiff/GeoTIFF
> Files: exported_from_original_sid_file.tif
> Size is 6946, 4800
> Coordinate System is:
> PROJCS["ED50 / UTM zone 31N",
>     GEOGCS["ED50",
>         DATUM["European_Datum_1950",
>             SPHEROID["International 1924",6378388,297.0000000000014,
>                 AUTHORITY["EPSG","7022"]],
>             AUTHORITY["EPSG","6230"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4230"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",3],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","23031"]]
> Origin = (327720.000000000000000,4730783.500000000000000)
> Pixel Size = (0.500000000000000,-0.500000000000000)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  327720.000, 4730783.500) (  0d53'46.94"E, 42d42'34.10"N)
> Lower Left  (  327720.000, 4728383.500) (  0d53'49.56"E, 42d41'16.35"N)
> Upper Right (  331193.000, 4730783.500) (  0d56'19.50"E, 42d42'36.88"N)
> Lower Right (  331193.000, 4728383.500) (  0d56'22.08"E, 42d41'19.12"N)
> Center      (  329456.500, 4729583.500) (  0d55'4.52"E, 42d41'56.62"N)
> Band 1 Block=6946x1 Type=Byte, ColorInterp=Red
> Band 2 Block=6946x1 Type=Byte, ColorInterp=Green
> Band 3 Block=6946x1 Type=Byte, ColorInterp=Blue
> In order to get it to work correctly, I had to use the right +towgs84
> parameters from
> http://earth-info.nga.mil/GandG/coordsys/onlinedatum/CountryEuropeTable.html. Although the table showed  -84 (+/-5), -107(+/-6), -120 (+/-3), for my own
> purposes -87, -98, -121 seemed to work best based on my source data.
> so the command line would be:
>  gdalwarp -s_srs "+proj=utm +zone=31 +ellps=intl +units=m
> +towgs84=-87,-101,-121 +no_defs" -t_srs EPSG:4326
> exported_from_original_sid_file.tif testout.tif
> Hope this helps someone else,
> - Ragi
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090514/6980b122/attachment.html
