[gdal-dev] GDALWarp GCP
Even Rouault even.rouault at mines-paris.org
Fri May 15 13:29:44 EDT 2009
Matt,
The symptoms you get are compatible with a common mistake : forgetting to
close the output dataset with GDALClose().
Otherwise, if it's a more serious issue, I'd advise you studying carefully the
source code of gdalwarp :
http://trac.osgeo.org/gdal/browser/trunk/gdal/apps/gdalwarp.cpp
(I've tested that if I modify gdalwarp.cpp to remove the closing of the output
dataset, I just get your symptoms)
Best regards,
Even
