[gdal-dev] HDF5 link problem
Clay, Bruce bclay at ball.com
Tue May 19 11:39:20 EDT 2009
I downloaded the latest version of HDF5 from
ftp://ftp.hdfgroup.org/HDF5/current/bin/windows/ and am trying to build
HDF5 support into GDAL 1.6.1.
Unfortuneately when I enable HDF5 suuport in the nmake.opt I get
unresolved link errors the interesting thing is that the errors are not
just for HDF5.  I do have SDE enabled and GRIB is enabled by default.  I
don't know that the first unresolved is but all of the error go away if
I take HDF5 out of the build.
   Creating library gdal_i.lib and object gdal_i.exp
gdalallregister.obj : error LNK2019: unresolved external symbol
_GDALRegister_GEOR referenced in function _GDALAllRegister at 0
_GDALRegister_HDF5Image referenced in function _GDALAllRegister at 0
_GDALRegister_HDF5 referenced in function _GDALAllRegister at 0
_GDALRegister_SDE referenced in function _GDALAllRegister at 0
_GDALRegister_GRIB referenced in function _GDALAllRegister at 0
gdal16.dll : fatal error LNK1120: 5 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\link.EXE"' : return code '0x460'
Stop.
Has anyone seen this behavior and/or have a solution?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090519/00548a6e/attachment.html
