[gdal-dev] GDALClose causing segfault
Tue May 19 14:05:58 EDT 2009
Wendy Fay Stevenson wrote:
> Hi
> I'm using the GDAL api on LINUX to warp an image.  I open a GIF image, warp it and save it as a Geotiff virtual file.  Then I use CreateCopy to create a GIF file.  Everything works fine except occasionally it gives a segfault when I attempt to call GDALClose on the original dataset (opened with GDALOpen).  It happens about every 1 in six times I run it.
> Has anybody else encountered this problem?
> Is there a specific order in which the datasets should be closed?
Wendy,
No reason for this is immediately obvious, but if you are working on
Linux I would strongly encourage you to try your program under valgrind.
It is very good at identifying heap corruption, memory overwrite, post-free
memory use and similar problems.
Best regards,
