[gdal-dev] error when opening wcs descriptor
Even Rouault even.rouault at mines-paris.org
Wed May 20 13:43:55 EDT 2009
Godofredo,
This is very surprising. wms and wcs drivers are only compiled if libcurl is
available.
Assuming your platform is Linux :
My guess is that you have configured a first time without libcurl support,
compiled, observed that libcurl support was missing, reconfigured with
libcurl support and compiled again... without cleaning. But the second
compilation did not recompile the necessary file(s), in that instance
port/cpl_http.cpp. If you just 'touch' it and compile, this should work. But
as a rule of thumb, the safest way is to make clean after running again
configure.
Best regards,
Even
Le Wednesday 20 May 2009 17:46:55 godofredo contreras, vous avez écrit :
> Hi:
> I compiled gdal 1.6 from svn source with libcurl, when running gdalinfo
> --formats wcs, and wms support is listed.
> But when running gdalinfo descriptor.xml I get the following error:
> ERROR 6: GDAL/OGR not compiled with libcurl support, remote requests not
> support ed.
> gdalinfo failed - unable to open 'nwgis.xml'.
> why is wcs format is listed as supported but giving an error of not being
> compiled with libcurl?
> Regards
> Godofredo Contreras
> _________________________________________________________________
> Hotmail® goes with you.
> http://windowslive.com/Tutorial/Hotmail/Mobile?ocid=TXT_TAGLM_WL_HM_Tutoria
>l_Mobile1_052009
