[gdal-dev] HDF5 link problem
Francesco P. Lovergine frankie at debian.org
Sat May 23 06:19:16 EDT 2009
On Tue, May 19, 2009 at 06:57:21PM +0200, Tamas Szekeres wrote:
> Bruce,
> I'm using hdf5-1.8.2 and it seems working well.
> You can obtain the binaries and build SDKs from here:
> http://vbkto.dyndns.org:1280/sdk/Default.aspx
> Best regards,
> Tamas
Note that 1.8 can be built in 1.6 compatibility mode or not.
Maybe that does the difference...
> 2009/5/19 Clay, Bruce <bclay at ball.com>
> >  I downloaded the latest version of HDF5 from
> > ftp://ftp.hdfgroup.org/HDF5/current/bin/windows/ and am trying to build
> > HDF5 support into GDAL 1.6.1.
> > Unfortuneately when I enable HDF5 suuport in the nmake.opt I get unresolved
> > link errors the interesting thing is that the errors are not just for HDF5.
> > I do have SDE enabled and GRIB is enabled by default.  I don’t know that the
> > first unresolved is but all of the error go away if I take HDF5 out of the
> > build.
