[gdal-dev] ogr2ogr encoding
Alexandre Dube adube at mapgears.com
Thu May 28 08:34:44 EDT 2009
Hi Frank,
Frank Warmerdam wrote:
> Alexandre,
> The OGR Postgres driver help says:
> By default it is assumed that text being sent to Postgres is in the UTF-8
> encoding.  This is fine for plain ASCII, but can result in errors for
> extended characters (ASCII 155+, LATIN1, etc).  While OGR provides no
> direct
> control over this, you can set the PGCLIENTENCODING environment variable
> to indicate the format being provided.  For instance, if your text is
> LATIN1 you could set the environment variable to LATIN1 before using OGR
> and input would be assumed to be LATIN1 instead of UTF-8. <p>
> Could you try setting the PGCLIENTENCODING environment variable to LATIN1
> before running ogr2ogr?
> Best regards,
I tried to set PGCLIENTENCODING to LATIN1 but I got the same error.  My
terminal is also set to latin1 and when I get the error I can see the
character correctly.  Changing it to utf8, I see a <?> character
instead, so I assume the dbf is in latin1.
Is there a way I could be sure of the dbf encoding ?  It's a file from
the tiger data set, maybe someone already know that ?  I checked in the
tiger doc but didn't find anything.
Thanks,
Alexandre Dubé
Mapgears
www.mapgears.com
