[gdal-dev] non-fully conform output of gdalwarp
Matthieu Rigal rigal at rapideye.de
Fri May 29 06:11:53 EDT 2009
Hi guys,
Working with GDAL 1.6.1, I got some strange result. It is not very
compromising, because the result is OK, but it shall be enhanced, or I shall
learn how to use it.
giving the following command :
gdalwarp -t_srs 'PROJCS["ETRS89_GRS80_3",GEOGCS["LUA_ETRS89",DATUM["D_GRS_1980",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",3500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",15.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]'
8_WGS84.tif 8_ETRS89.tif
will create the desired file, and project it fine, but doing :
gdalinfo 8_ETRS89.tif
will show :
        DATUM["unknown",
            SPHEROID["unnamed",6378137,298.2572221010042]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",15],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",3500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Why is the Datum set to unknown and the spheroid to unnamed ?
It also causes some other software to warn that the projection is not the same
(as the desired)...
Best regards,
Matthieu
Matthieu Rigal
Product Development
RapidEye AG                           Tel: +49-(0)3381-89 04 331
Molkenmarkt 30                       Fax: +49-(0)3381-89 04 101
14776 Brandenburg/Havel
Germany                                  http://www.rapideye.de
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
