[gdal-dev] 8 bit or 24 bit
    Frank Warmerdam
    warmerdam at pobox.com
    Sun May 31 14:07:29 EDT 2009
jor sion wrote:
> Hi,
> How to judge an image in hdf files is 8 bit or 24 bit?
Jor,
Check the number of bands with GDALDataset::GetRasterCount().  If this is
three, then it is likely what you call 24bit,and if it is 1 then it is
likely 8bit.
Best regards,
