[gdal-dev] Building a Mercator Image from Un-projected data..Major confusion and help requested.
Cassanova, Bill BCassanova at weather.com
Mon Nov 2 16:47:19 EST 2009
Well, I sorta tried that:
gdalwarp -s_src '+proj=WGS84' -t_srs '+proj=merc'
hiradff_200910121800_f180_weather_radar.tiff foo.tiff
And the reply is:
Usage: gdalwarp [--help-general] [--formats]
    [-s_srs srs_def] [-t_srs srs_def] [-to "NAME=VALUE"]
    [-order n] [-tps] [-rpc] [-geoloc] [-et err_threshold]
    [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
    [-wo "NAME=VALUE"] [-ot Byte/Int16/...] [-wt Byte/Int16]
    [-srcnodata "value [value...]"] [-dstnodata "value [value...]"]
-dstalpha
    [-r resampling_method] [-wm memory_in_mb] [-multi] [-q]
    [-cutline datasource] [-cl layer] [-cwhere expression]
    [-csql statement] [-cblend dist_in_pixels]
    [-of format] [-co "NAME=VALUE"]*
    srcfile* dstfile
Available resampling methods:
    near (default), bilinear, cubic, cubicspline, lanczos.
The file is something GDAL should understand:
[vizuser at vizintqa exploded_visualizer]$ gdalinfo
Driver: GTiff/GeoTIFF
Files: hiradff_200910121800_f180_weather_radar.tiff
Size is 5796, 2464
Coordinate System is:
GEOGCS["Coordinate System imported from GRIB file",
    DATUM["unknown",
        SPHEROID["unnamed",6367470,0]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
Origin = (234.010419999999982,49.706487000000003)
Pixel Size = (0.010399000000000,-0.010399000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (     234.010,      49.706) (234d 0'37.51"E, 49d42'23.35"N)
Lower Left  (     234.010,      24.083) (234d 0'37.51"E, 24d 5'0.06"N)
Upper Right (     294.283,      49.706) (294d16'58.89"E, 49d42'23.35"N)
Lower Right (     294.283,      24.083) (294d16'58.89"E, 24d 5'0.06"N)
Center      (     264.147,      36.895) (264d 8'48.20"E, 36d53'41.71"N)
Band 1 Block=5796x1 Type=Byte, ColorInterp=Red
  Mask Flags: PER_DATASET ALPHA
Band 2 Block=5796x1 Type=Byte, ColorInterp=Green
Band 3 Block=5796x1 Type=Byte, ColorInterp=Blue
Band 4 Block=5796x1 Type=Byte, ColorInterp=Alpha
Am I missing something here?  I would however prefer to do it with code
so that I can go directly from my data to an image without the
intermediate step
Of using gdalwarp.
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Christopher
Barker
Sent: Monday, November 02, 2009 4:39 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Building a Mercator Image from Un-projected
Cassanova, Bill wrote:
> I am looking to gain a better understanding of how I can use GDAL to
> build a Mercator Image from un-projected data.
Do you need to write your own code for this?, or could you just use the
  gdalwarp utility? (maybe after converting to a format gdal knows).
If you do need your own code, you might look at the gdalwarp code.
Which brings up a question I could answer by reading the source, but
since I'm here:
Is the core warping functionality in the GDAL API (and wrapped for
Python?), or in the gdalwarp code -- I may need to do some warping in
code as well.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
Chris.Barker at noaa.gov
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091102/2bfcb0bc/attachment-0001.html
