[gdal-dev] Problem with OSR projection on "+init=IGNF:LAMBE +wktext"
Jean Michel PIERRET jmp at geosys.com
Tue Nov 3 13:28:18 EST 2009
                I'm using OSR (on GDAL 1.6.1) bindings in C# to project
points, and I have problem with the projection "+init=IGNF:LAMBE +wktext" to
"+init=IGNF:LAMB93"
At the first execution, I have one result and on all the others I have
another results.
An exemple :
                SpatialReference _srin = null;
                SpatialReference _srout = null;
                CoordinateTransformation _ct = null;
                double[] x, y;
                _srin = new SpatialReference("");
                _srin.ImportFromProj4("+init=IGNF:LAMBE +wktext");
                _srout = new SpatialReference("");
                _srout.ImportFromProj4("+init=IGNF:LAMB93");
                _ct = new CoordinateTransformation(_srin, _srout);
                x = new double[] { 540000 };
                y = new double[] { 1820000 };
                _ct.TransformPoints(1, x, y, null);
                Console.WriteLine(x[0] + " - " + y[0]);
                // Return : 586336,591390395 - 6254404,95793043
                //Return : 586281,605619939 - 6254404,35662961
                _ct.Dispose();
                _srin.Dispose();
                _srout.Dispose();
Thanks for your Help.
Jean michel Pierret
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091103/faf45227/attachment.html
