[gdal-dev] Re: increment in GMT output
Sebastian P. Luque spluque at gmail.com
Wed Nov 4 22:04:22 EST 2009
On Thu, 05 Nov 2009 01:19:58 +0000,
Joaquim Luis <jluis at ualg.pt> wrote:
> Sebastian, There is actually more than one error here. Besides the
> negative y_inc the row/columns info is also wrong.  Note for instances
> the X info
> x_min: 0 x_max: 1216 x_inc: 1 name: meters nx: 1216
> Either x_min should be 1 OR x_max = 1215.
Thanks for the heads-up!  I've struggled with this all afternoon, and at
this point I'm thinking it will be easier to work with the geotiff
alternative they offer, although it uses a datum that is inappropriate:
ftp://ftp-projects.zmaw.de/seaice/AMSR-E_ASI_IceConc/geotiff
Seb
