[Gdal-dev] gdal_contour crashing
NopMap ekkehart at gmx.de
Wed Nov 11 14:00:16 EST 2009
Hi!
I have sudden problem with gdal_contour after using ist successfully many
times. There seems to be a problem with a certain area. When I tried it
first, gdal_contour quit with an out-of-memory message, exceeding 2GB of
virtual memory. When I reduced the area and called
gdal_merge.py -o M:\srtm\Hillshading_srtm.tif -ul_lr 6.3 45.4 9.2 43.5
M:\srtm\
gdal_contour -i 10 -snodata 32767 -a height M:\srtm\Hillshading_srtm.tif
M:\srtm\Hillshading_shape.shp
it just hung at about 80% completion, no more CPU activity. It worked on a
neighboring area before.
The data was merged from downloaded CGIAR 5x5 data. Hillshading_srtm.tif
looks good in a viewer and in gdal_info and the perrygeo hillshade.exe was
able to produce nice shadings from the same data.
GDAL Version is 160, binaries on Windows XP.
What can I do to track down this problem, except for making the area smaller
and smaller? I have not found a verbose setting on gdal_contour. Any ideas
what could cause this behaviour?
thanks
          Nop
View this message in context: http://n2.nabble.com/gdal-contour-crashing-tp3988183p3988183.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
