[gdal-dev] Re: importing HDF sea ice grid with unusual projection
Hermann Peifer peifer at gmx.eu
Thu Nov 12 09:44:41 EST 2009
 > I've also tried using the proj4 strings offered
 > for that EPSG, but the results are the same.
Hmm. It it looks to me that this should work:
gdal_translate -a_srs "+proj=stere +lat_0=90 +lat_ts=70 +lon_0=-45 +k=1
+x_0=0 +y_0=0 +a=6378273 +b=6356889.449 +units=m +no_defs" -a_ullr ...
See [1] for gdalinfo's output from the resulting GeoTIFF.
Your case seems to be related to the recently opened ticket
http://trac.osgeo.org/gdal/ticket/3220
Hermann
[1]
$ gdalinfo  asi-n6250-20020619-v5i_proj4.tif
Driver: GTiff/GeoTIFF
Files: asi-n6250-20020619-v5i_proj4.tif
Size is 1216, 1792
Coordinate System is:
PROJCS["unnamed",
     GEOGCS["GCS Name = unnamed ellipse|Datum = unknown|Ellipsoid =
unnamed|Primem = Greenwich|",
         DATUM["unknown",
             SPHEROID["unnamed",6378273,298.279411123064]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Polar_Stereographic"],
     PARAMETER["latitude_of_origin",70],
     PARAMETER["central_meridian",-45],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]]]
Origin = (-3800000.000000000000000,5600000.000000000000000)
Pixel Size = (6250.000000000000000,-6250.000000000000000)
Metadata:
Seb wrote:
> Hi,
> I originally posted to the GRASS list, but it was suggested that it
> would be more appropriate here, given that GRASS uses GDAL for this
> particular problem.
> I'm in the process of importing sea ice concentration data from:
> ftp://ftp-projects.zmaw.de/seaice/AMSR-E_ASI_IceConc
> I have chosen to use their HDF product because their Geotiff uses a
> WGS84 datum that results in up to 500 m error at the borders, according
> to their info files at the root of each subdirectory.
> The grids are not georeferenced, but they use the same grid that NSIDC
> does with the specifications given here:
> http://nsidc.org/data/docs/daac/nsidc0002_ssmi_seaice.gd.html
> Fortunately, there's an EPSG code (3411, for the northern hemisphere)
> for that projection.
> gdalinfo on the HDF file:
> ---<--------------------cut here---------------start------------------->---
> $ gdalinfo asi-n6250-20020619-v5i.hdf
> Driver: HDF4Image/HDF4 Dataset
> Files: asi-n6250-20020619-v5i.hdf
> Size is 1216, 1792
> Coordinate System is `'
> Metadata:
>   valid_range=0, 1
>   long_name=ASI Ice Concentration, 20020619, res: 6.25000, AMSR-E, ASI Version: 5.5i, missing data interpolated.
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 1792.0)
> Upper Right ( 1216.0,    0.0)
> Lower Right ( 1216.0, 1792.0)
> Center      (  608.0,  896.0)
> Band 1 Block=1216x82 Type=Float32, ColorInterp=Gray
> ---<--------------------cut here---------------end--------------------->---
> Converting to GTiff for importing into GRASS, using the EPSG code and
> bounds in the NSIDC's info:
> $ gdal_translate -of GTiff -a_srs EPSG:3411 -a_ullr -3800000 5600000 3800000 -5600000 asi-n6250-20020619-v5i.hdf asi-n6250-20020619-v5i.tif
> Warning 6: A dataset opened by GDALOpenShared should have the same filename (asi-n6250-20020619-v5i.hdf) and description (HDF4_SDS:UNKNOWN:"asi-n6250-20020619-v5i.hdf":0)
> Input file size is 1216, 1792
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> $ gdalinfo asi-n6250-20020619-v5i.tif
> Files: asi-n6250-20020619-v5i.tif
> Size is 1216, 1792
> PROJCS["NSIDC Sea Ice Polar Stereographic North",
>     GEOGCS["Unspecified datum based upon the Hughes 1980 ellipsoid",
>         DATUM["Not_specified_based_on_Hughes_1980_ellipsoid",
>             SPHEROID["Hughes 1980",6378273,298.279411123061,
>                 AUTHORITY["EPSG","7058"]],
>             AUTHORITY["EPSG","6054"]],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4054"]],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","3411"]]
> Metadata:
>   AREA_OR_POINT=Area
>   valid_range=0, 1
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-3800000.000, 5600000.000)
> Lower Left  (-3800000.000,-5600000.000)
> Upper Right ( 3800000.000, 5600000.000)
> Lower Right ( 3800000.000,-5600000.000)
> Center      (   0.0000000,   0.0000000)
> Band 1 Block=1216x1 Type=Float32, ColorInterp=Gray
> So far so good, but when importing into a GRASS location:
> r.in.gdal in=/home/sluque/tmp/asi-n6250-20020619-v5i.tif out=test location=Test
> WARNING: No projection name! Projection parameters likely to be
>          meaningless.
> WARNING: Datum <Not_specified_based_on_Hughes_1980_ellipsoid> not
>          recognised by GRASS and no parameters found
> Location <Test> created
>  100%
> r.in.gdal complete. Raster map <test> created.
> What is missing here?  I've also tried using the proj4 strings offered
> for that EPSG, but the results are the same.  Any tips would be appreciated.
> Cheers,
