[gdal-dev] Setting the spatial reference of an existing shapefile with OGR
Even Rouault even.rouault at mines-paris.org
Thu Nov 12 19:43:28 EST 2009
Selon Jason Roberts <jason.roberts at duke.edu>:
> Greetings OGR experts,
> I have a shapefile for which no spatial reference was defined when the
> shapefile was created, but I know the spatial reference and would like to
> set it on this existing shapefile. Is this possible with the OGR Python API?
You're correct. There's no direct (Python or C) API for this.
> It looks like the only place that takes an OGRSpatialReference instance is
> OGRDataSource::CreateLayer. This suggests that the only way to do it is to
> call CreateLayer with the appropriate OGRSpatialReference instance and then
> write all of the code to create the fields and copy all of the features from
> the existing layer to the new one. Is this correct?
Yes. Or... you could cheat a bit. In the case of a shapefile, the spatial
reference is written in a .prj file. So technically you can create a fake empty
shapefile with the right spatial reference, close it, rename the .prj to have
the same basename as your shapefile of interes and re-open it.
> Thanks very much for any suggestions you can provide,
> Jason
