[gdal-dev] Problem to implement a new format
Fri Nov 13 10:01:20 EST 2009
Vincent Honnet wrote:
> Hi,
> I'm trying to implement a new format for my GDal and I have some
> problems. For now I don't want to integrate it to the GDal source code
> but only in gdal_translate. I call the registering method just after the
> call to GDALAllRegister.
> I implemented the Dataset methods Open, the RasterBand methods
> IReadBlock and IWriteBlock, the method GDalRegister_format where Open is
> given to poDriver->pfnOpen, CreateCopy to poDriver->pfnCreateCopy and
> Create to  and poDriver->pfnCreate and the driver is registered.
> A request on the available formats on this version of GDal_Translate
> shows that the format is registered.
> A convertion request from a GeoTiff to this format crashes in my method
> Open because the object GDALOpenInfo is wrong (pszFilename is a bad
> pointer for example).
Vincent,
I'm surprised your open method is being called for a geotiff if your
driver was registered after the geotiff driver.
 > Moreover, my method CreateCopy is never called
> even if GDALCreateCopy is called.
It it possible you assigned your Open method to the pfnCreateCopy
function?
> The platform is Windows XP with GDal 1.6 and visual studio 2005 pro.
> Did I forget something ?
It is really hard to provide advice without the source code.  I'm basically
guessing.
Best regards,
