=?gb2312?B?tPC4tDogW2dkYWwtZGV2XSBHREFMIEMjIGludGVyZmFjZQ==?=
yanbohe at cma.gov.cn yanbohe at cma.gov.cn
Fri Nov 13 10:38:07 EST 2009
Dear Tamas=A3=AC=20
Thanks for your reply and I checked the URLS in your email. Yes there =
are
some binary packages supporting C#. But I checked the supporting raster
formats, I found the one I will to use, HDF4 format is not included. Is
there any ideas or good suggestions?=20
Thanks a lot
Yanbo   =20
-----=D3=CA=BC=FE=D4=AD=BC=FE-----
=B7=A2=BC=FE=C8=CB: Tamas Szekeres [mailto:szekerest at gmail.com]=20
=B7=A2=CB=CD=CA=B1=BC=E4: 2009=C4=EA11=D4=C213=C8=D5 23:11
=CA=D5=BC=FE=C8=CB: yanbohe at cma.gov.cn
=B3=AD=CB=CD: gdal-dev at lists.osgeo.org
=D6=F7=CC=E2: Re: [gdal-dev] GDAL C# interface
You could try one of the packages available from here for example:
http://vbkto.dyndns.org/sdk/
Best regards,
Tamas
2009/11/13  <yanbohe at cma.gov.cn>:
> Dear All,
> Who have GDAL binary DLL libs for C#? I download the source code and =
did
not
> successes to compile them for C# interface.
> gdal-dev mailing list
